Looking for EGR
I've seen a photo posted by CobraXP of the rear of a 5.0 engine with the mounting plate for the EGR, but mine is different.
Can anyone post a pic or description of an EGR on this engine?
I was told I could remove and clean it to clear a CEL.
Thanks for any help!!!
You have the early style intake/EGR setup. You do not have a DPFE sensor. Your EGR is in the same position as the one I posted, just looks different. Find your throttle body. Follow the intake elbow around to the back. The EGR valve is mounted basically in the same place as on the pic I posted, but bolts directly to the elbow. You will see it has an orangeish looking plunger in it...
What you are seeing on the fuel rail is your fuel pressure regulator.
I have taken mine off a few times, and with the addtion of the supercharger, it gave me a little extra hand room. But I won't forget the first time I did it...
While you have it off, I would look at changing the PCV valve and maybe the EGR solenoid (the black cylinder mounted just to the side of the EGR valve). The solenoid is only around $15.00, and it is just easier to do it while you have everything taken apart...
