Sponsored by: Real Truck
Door noise on supercab.
Old Feb 11, 2002 | 11:02 AM
NewFordSD's Avatar
NewFordSD
I've noticed a rattle that seems to be coming from my door. Even on the smoothest of surfaces it rattles slightly and/or creaks. When doors are closed there is no movement as I checked from the outside. Sounds like the window or door. Anyone else have this problem. It's starting to get annoying.
Old Feb 11, 2002 | 11:54 AM
JEFFnSTL's Avatar
JEFFnSTL
I had the same type of syptoms. What mine turned out to be was the pass. cab door. The lower lock clasp was not laching. Took it to the dealer and they fixed it.
2001,f-250,4x4,5.4,3.73,lb,sc
Old Feb 11, 2002 | 01:09 PM
3fordfamily's Avatar
3fordfamily
Got the same problem with mine, it sounds like the squak that comes from those styrofoam icechest....pretty annoying
Old Feb 11, 2002 | 02:32 PM
NewFordSD's Avatar
NewFordSD
That is exactly the way it sounds. Exactly. What are you going to do about it???
Old Feb 11, 2002 | 03:48 PM
CEEJR's Avatar
CEEJR
My driver side doors creak squeek and whistle told it was "normal truck noise". Now that my truck is in for a tranny. problem they said they would fix the doors.
Old Feb 11, 2002 | 04:51 PM
jlsworks's Avatar
jlsworks
I have it too. It's been in the shop on several occasions for "adjustments", the dealer says they can't find a TSB on the subject and the adjustments last about a week, when the grease goes away.
I've had the seat bottoms and slide rails replaced on my captains chair, now the back portion creaks. Oh well, they sure are comfortable seats.
Old Feb 12, 2002 | 07:12 AM
3fordfamily
What I have done in the past is jiggle the back door handle a few times letting it slam back into position. This seems to work for a little while then it comes back. I talked to the dealer and he said the same thing, it is "normal" for these trucks...It may be normal, but it sure is annoying...I wonder is greasing up the components inside the handle will work??
Old Feb 12, 2002 | 09:00 AM
Big's Avatar
Big
Damn, I am lazy! I have had the same problem on my '00 F-250 for some time now. My noise comes from the back driver's side door on my Super Cab. It is intermittant so when I have time to try to determine the source of the rattle, it goes away! But when I am busy as he!!, there it is! My local Ford Dealers are about as helpful as an air conditioner in January. I will keep tabs on this to see what you all find out.
Big
Old Feb 12, 2002 | 03:17 PM
Shepard's Avatar
Shepard
I have the same, (I think) noise on my crew cab. I have thought it was the door gaskets, seals. I happens for me only when the truck is turning or on rough road or coming out of a driveway, stuff like that. Sort of like the cab is flexing a bit. I have thought about putting some silicone on the rubber seals around the door to see if it stops. I guess I have just become used to it so have not tried to pin it down or fix it yet.
Old Mar 1, 2002 | 06:20 PM
neveragain's Avatar
neveragain
All I have to say is that Ford makes a really crappy truck. I have had my 2001 F-250 CC SD 5.4l slappin piece of crap back to the dealer 6 times already for the doors. All of them make noise!!!! They creek, rattle, and squeak. This is my first and last Ford.
Old Mar 4, 2002 | 08:37 AM
enduringexplorer's Avatar
enduringexplorer
neveragain, sounds like you are a prime candidate for a Toyota!! Had 1 in '87. Was great for a single guy and groceries. Fun in snow. Quiet. Plain. Weak. No power. Completely rusted out in 5 years.
Old Mar 4, 2002 | 06:08 PM
Medic 13's Avatar
Medic 13
With out going in to why i had to take my doors apart I found out why the stupid thing whistle. There is absolutely no seal around the exterior door handles. you can even see light through all four of them. I have a 1999 model and I don't know if they corrected this later on but I kinda wonder about this.
Old Mar 4, 2002 | 06:42 PM
FortyFords's Avatar
FortyFords
sagmill
Oct 23, 2017 09:41 AM
jhaas63
Jul 29, 2014 08:37 AM
billybobzia
2009 - 2014 F150
16
Jun 25, 2014 09:07 AM
kyle1979ford
Mar 28, 2014 08:16 PM
bamacommander
2004 - 2008 F150
Jan 18, 2009 01:21 PM
