My cruise has stopped working. No lights flashing, nothing. I looked at this thread: cruise control not working, but it was left sorta open... and not didn't solve my problem.
I tried bigdawg460's method of getting a cruise trouble code, holding "on" while turning key to on. Nothing. But, if I hold "off", I can get the cruise light to flash once. Pressing any of the other buttons after this does nothing.
Can anyone confirm the buttons and sequence required to get the code and then the meanings of whatever code I get?
Is the speedo acting funning like jumping from 0 to 25 if so I would pull the VSS that is mounted on the top of rear end housing and check it if has what looks like iron filing on it clean it and put it back or just replace it they are about 20 bucks from dorf
PINPOINT TEST A: THE SPEED CONTROL IS INOPERATIVE
² A1: CHECK THE SPEED CONTROL ACTUATOR ATTACHMENT TO THROTTLE
² A2: CHECK THE VOLTAGE TO THE SPEED CONTROL SERVO
² A3: CHECK FUSE JUNCTION PANEL FUSE 28 (10A) (MOTORHOME FUSE 26 [10A])
² A4: CHECK THE SPEED CONTROL SERVO GROUND CIRCUIT 57 (BK)
² A5: CHECK FOR BRAKE PEDAL POSITION (BPP) SWITCH INPUT WITH NO BRAKES APPLIED
² A6: CHECK THE BRAKE/CLUTCH CIRCUIT
² A7: CHECK THE DEACTIVATOR SWITCH INPUT TO SPEED CONTROL SERVO
² A8: CHECK THE DEACTIVATOR SWITCH CIRCUIT
² A9: CHECK DEACTIVATOR SWITCH POWER
² A10: CHECK FOR STUCK SPEED CONTROL ACTUATOR SWITCH
² A11: CHECK THE SPEED CONTROL ACTUATOR SWITCH OPERATION
² A12: CHECK CIRCUIT 151 (LB/BK) FOR AN OPEN
² A13: CHECK THE AIR BAG SLIDING CONTACT OR CONTROL AND BRUSH ASSEMBLY FOR AN OPEN
² A14: CHECK THE SET/ACCEL SWITCH
² A15: CHECK THE SPEEDOMETER
² A16: CHECK CIRCUIT 676 (PK/O) (MOTORHOME 1203 [BK/BL]) FOR AN OPEN
² A17: CHECK THE SPEED CONTROL ACTUATOR SWITCH
² A18: CHECK CIRCUIT 151 (LB/BK) FOR SHORT TO POWER
² A19: CHECK CIRCUIT 22 (LB/BK) FOR AN OPEN
² A20: CHECK CIRCUIT 810 (R/LG) FOR AN OPEN
² A21: CHECK CIRCUIT 306 (T/LB) FOR AN OPEN
² A22: CHECK THE CPP SWITCH
I pulled this off my CD Up to 01 but maybe you can check some of the simple stuff.
It quit again. Then I tilted the wheel down and it started working. I haven't been able to make it quit working now. Maybe a broken wire in the column?
I had a similar problem with my 2000 SD PSD with a 6 speed manual, I found a bad clutch switch which cost about 40 bucks. Not sure what kind of transmission you have, but hope this gives you one more thing to look at.
