Sponsored by: Real Truck
auxillary lights
Old Feb 17, 2002 | 12:08 PM
slammer's Avatar
slammer
auxillary lights
Hi,I'm brand new to the site but have owned many fords. I have a 2000 Ford F250 EC 4x4 and want to put the factory auxillary lights that come on the new 250/350s. Will they fit or do I have to change the bumper assembly.
Thanks alot
Old Feb 17, 2002 | 10:58 PM
NoMo's Avatar
NoMo
auxillary lights
Welcome!
The factory fog lights are not known to be of the highest quality. I'd recommend buying a set of aftermarket lights. Either way, you shouldn't need a new bumper... they just mount in the lower opening.
Old Feb 18, 2002 | 11:31 AM
Edmo's Avatar
Edmo
auxillary lights
My F250 has the aux low-beam lights mounted in the lower bumper area and they help... Some... If I were doing it again, I would get some aftermarket lights from PIAA or some other manufacturer. You will spend a few more $$$, but you will be pleased with the brighter results. I'm thinking of replacing the bulbs in mine with aftermarket bulbs (~$60).
OBTW, I just installed PIAA 80 series driving lights tied into my high-beams... WOW!
Edmo
Old Feb 18, 2002 | 06:24 PM
austinopa's Avatar
austinopa
auxillary lights
I put the "Ford" lights in my 2000. You will have to add a strap at the top of the bumper, over eack light. The 2000 have a cut out in the rolled down lip where the lights mount. It is easy, buy about 18" of 3/16" strap and put a bolt on each side. Pull the bumber off it is easier than working from below. Also you will have to cut out the plastic trim.
Old Feb 18, 2002 | 08:06 PM
superdutyspv's Avatar
superdutyspv
auxillary lights
My Ford auxillary lights are Hellas. I ordered them out of the Ford Super Duty accessory catalog. The 2000 didn't come with fog lights, so I ordered them. I was curious who made them, and looked at my fog lights, and sure enough, they say HELLA.
Old Feb 25, 2002 | 10:10 AM
Waxy's Avatar
Waxy
auxillary lights
Old Mar 6, 2002 | 08:23 PM
Crocodile's Avatar
Crocodile
auxillary lights
I sold my factory fog lamps off my 2001 Super Duty to a friend with a 2000. The bracket/light assembly will mount (the screw holes exist on your truck) but you won't have the harness. You will have to wire them yourself.
Old Mar 6, 2002 | 08:45 PM
redranger1's Avatar
redranger1
auxillary lights
what? i have never heard of one of these? where do i find one? how do i get it? i want one!!!
-nathan
Old Mar 6, 2002 | 09:23 PM
Monsta's Avatar
Monsta
Sit. Stay.
auxillary lights
Go see yer dealer Nathan...He's got one.
Old Mar 7, 2002 | 12:32 PM
redranger1's Avatar
redranger1
auxillary lights
thanks monsta!
-nathan
Old Mar 8, 2002 | 05:47 AM
plumr's Avatar
plumr
auxillary lights
I just got a set for my rig from FORD I have a 2000 I thought I was gonna get the same one's the newer trucks have. I got HELLA's they told me I would have to get a new bumper if I wanted the newer ones. I am happy with the HELLA.
2000,F-250,4+4,Auto,Ext.Cab,Long Bed
