Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
steel rod bender
Old Feb 14, 2004 | 04:05 PM
uk1050's Avatar
uk1050
steelrod bender
for anyone who watches orange county choppers on
the discovery channel. what is that tool that they use that
bends there round steel bars it has a big wheel on the side
to crank the bends,and where can i get one.
Old Feb 14, 2004 | 05:22 PM
CAT_man_963's Avatar
CAT_man_963
I think you're talking about a tubing bender?? It bends tubing without kinking or folding it? Or are they bending solid rods?
A good tubing bender is pretty expensive, but something to bend solid is fairly cheap. Check out mtechsupply.com for all kinds of stuff
Old Feb 14, 2004 | 06:59 PM
Kikko's Avatar
Kikko
Check out Harbor Freight. They sell it for solid round and flat stock.
Old Feb 14, 2004 | 07:27 PM
Torque1st's Avatar
Torque1st
Posting Legend
There are cheap pipe benders also but they WILL NOT bend tube.
Old Feb 15, 2004 | 10:38 AM
tock's Avatar
tock
It's called a ring roller. http://www.metalcraftcanada.com/
(Many people like to replace the handle with a wheel to get better control.)
Old Feb 15, 2004 | 07:44 PM
Ghostgunn's Avatar
Ghostgunn
Ring Roller
Also check shop outfitters, I believe at www.plasmacam.com. As well as Grizzly tools form bellingham , Washington. I have personally been to their headquarters in Washington and they have alot of great price competitive tools. I may add that tubing benders bend tubing , pipe benders bend pipe there is a difference as you will really distort your tubing if you place it in a pipe bender, pipe benders are also ususally alot lower tech and therefore cheaper.-- the best of them is a hossfeld #2. THey are expensive-- may try lowbuck tools for a cheaper model if you want a tubing bender. I believe what you are descirbing although is the ring roller, it is usually the tool they use for bending smaller diameter rod for areas such as fneder supports etc.,
ghunt
Garage & Workshop
Mar 4, 2008 03:12 PM
Domenico
Garage & Workshop
Feb 10, 2008 09:51 AM
moxy123
Paint & Bodywork
Dec 31, 2007 03:26 PM
anfo
Garage & Workshop
17
Apr 23, 2004 07:34 AM
jdolby
Jan 21, 2004 12:07 PM
