Brake lines: Steel tube vs. Braided Hose
Anybody ever replace a steel tube brake line with a stainless steel braided hose? Will it burst under high pressure?
I need to replace my steel tube front drivers side. It will be a pain to bend thru the frame to connect. A braided hose will be easy.
For 1988 F250 4X4.
Thanks
JD
For 1988 F250 4X4.
Thanks
JD
on
1 Post
They both have advantages and disadvantages. The braided is easier to bend but with the wire around it, it will hold in moisture and salt, dirt, etc. making it rust faster. The regular line is harder to bend but may last longer. If I had to put a line in a hard area to get into and had to bend by hand I would probably use the braided stuff. But for everything else I would just use the regular stuff. Good luck!
-Matt
-Matt
The on;ly place you should use braided line is as a replacement for the flexible rubber hose already on the truck in places where the line has some movement. Using braided line in other areas results in a spongy brake pedal as the flexible line does expand some when you apply the brakes.
The above is common practice on race cars. I would also caution you that most braided line (at least the stainless braided type) is not DOT approved. This doesn't mean it isn't as good or better than the OEM stuff, it just means it is not legal for on road use. This is no big deal unless you get in a wreck and some lawyer finds out the lines are not OEM type. He will then find a jury of idiots and convince them the wreck was your fault because you had non-OEM type parts in the brake system.
Patriotic Rottweiler
09-26-2014 02:40 PM
chad.deraps
05-25-2011 04:09 PM
