1978 - 1996 Big Bronco
Largest tire size
Old Feb 14, 2004 | 09:46 AM
Errgo's Avatar
Errgo
Largest tire size
What is the largest size tire that will fit on my stock 93 Bronco without a lift kit and without rubbing the radius arms or the front bumper? I know this question has probably been asked a million times but I can’t find anything on this subject using the search engine or in the current posts. Thanks for your help.
Old Feb 14, 2004 | 09:53 AM
holleyman's Avatar
holleyman
32X11.50X15 on stock suspension.
Old Feb 14, 2004 | 10:13 AM
tite4x4's Avatar
tite4x4
This seems to be a regular thread. But, and even though I have a '90, I have had 33"x12.5" tires on 15x10 rims at stock highth. Had no rubbing at all anywhere. The new Tires stuffed the wheel wells very nicely. Had alot of thumbs up. The only real problem was that there was only about an inch of clearance between tires and fenders. A little too tight to do any serious wheeling. So I opted to do a 4" suspension lift. Still looks cool.
Old Feb 14, 2004 | 01:28 PM
chux's Avatar
chux
i'm running 33x12.50 on 15x8's. i get a little rubbing when i turn it hard,but i never went out and adjusted the steering stops either. the only time i rubbed the fenders was when i was racing across the desert and i jumped it. nothing too bad bent up the chrome trim under the wheelwell a bit.
Old Feb 14, 2004 | 01:38 PM
ohrtman19's Avatar
ohrtman19
my neighbor has ran 35x12.5/15 on a stock before and no rubbing unless hit a big bump going fast turning right
Old Feb 16, 2004 | 07:00 AM
94 XLT White/ Silver 302's Avatar
I just put 32x11.50 BFG. all terrains on15x8 Mickey Thomson classic 2 wheels. On my 94 Bronco with no lift. I did had to space my bumper out 1/2" and its still tight. I can't put my air dam back on until I get longer bolts to space the bumper out farther. But it sure looks good with the 32s. Using gps my speedometer is off 3.8mph. at 60mph. Truck still pulls good with the 32s.
Old Feb 16, 2004 | 07:34 PM
buckinbronco'95's Avatar
buckinbronco'95
i ran 33x12.5 on my bronc no problem on my 95 then gave em to my friend who put them on his stock 88 bronc too... also no problem
Old Feb 16, 2004 | 10:32 PM
fordnut74's Avatar
fordnut74
31x10.50, stock suspension, no rubbing at all, anywhere under any wheeling conditions, and without adjusting the wheel stops, or the front bumber.
Old Feb 16, 2004 | 11:43 PM
ANdrewdrice's Avatar
ANdrewdrice
I put 32-11.50r15s BFG allterrainTaKo on my bone stock 95. it rubs when I turs all of the way.
