Transfer case shifter
Old Feb 14, 2004 | 08:12 AM
Yamahauler's Avatar
Yamahauler
Unhappy Transfer case shifter
Hi guy's!
I've got a recently developed problem with my shifter on the transfer case in a 1993 F-150 (302 AO4D)
I plow snow with this hard working baby and normally have no problems whatsoever. But just recentlyI'm having trouble getting from 4 wheel High or Low back to 2 wheel. it seems as though the shifter doesn't want to lift like it should when you bring it back out of 4 wheel Low. It will go to 4 wheel high and nuteral O.K. You really have to pull up hard to get it into 2 wd. I had some exhaust work done the other day and had the guy's take a quick peek at it and give it some lube but it doesn't seem to have helped. Any ideas would be greatly appreciated
Old Feb 14, 2004 | 10:02 AM
frederic's Avatar
frederic
Sadly, the only way to fix this is to take it out, tear it apart, and clean out the sliding mechanism the shifter is connected to.
You probably have sand, salt, and other goo in it.
Old Feb 15, 2004 | 09:18 AM
Yamahauler's Avatar
Yamahauler
Thanks Frederic, but I removed the boot on the shifter and lubed the crap out of the slide that the shift rod goes through and it seems to have helped a little bit. I don't know if there's supposed to be a protective boot on the bottom of that rod or not I can't see the bottom for ice and snow right now but there's definitely one on the top, also I don't know if there is a spring inside that tube the shift rod goes through, I'll have to check that out and look at it if I can get it inside somewhere and let it thaw out. the problem is we've had so much snow up here I can't take the truck out of service for too long.
Old Feb 15, 2004 | 10:01 AM
frederic's Avatar
frederic
I can get it inside somewhere and let it thaw out. the problem is we've had so much snow up here I can't take the truck out of service for too long. [/B]
I hear that...
This is why I hate snow. Vehicles I own only seem to break in incliment weather, just so I have to lie on my back in snow or ice.
Its just the way it is heh-heh. Good luck with the repair.
Old Feb 15, 2004 | 12:00 PM
ATC_250SX's Avatar
ATC_250SX
Whenever your ready to send that snow to the northeast, IM WAITING, we have no snow here, on your shifter i have heard of them getting corroded to the shaft, take a look underneith and see if you can just take it off and give some grease to it.
Old Feb 15, 2004 | 12:55 PM
frederic's Avatar
frederic
As long as the snow hits new hampshire and not new jersey, I'm happy !
DeanBob
Apr 1, 2007 09:13 AM
KENS94F1504*4
Sep 1, 2005 03:25 PM
bass4163
Jun 30, 2005 11:13 AM
frankc
1997 - 2003 F150
Nov 3, 2003 12:34 PM
