are the new ones coming with the black spring type things that go over the lugs? mine only has 3 per wheel maybe try adding some more. or just put a dab of silcone on them and snap em on.
are ur lug nuts factory?
Are you getting the right ones when you buy them?
These trucks come with either 19mm or 21mm wheel nuts. If you had the 19mm nuts and put on caps for 21mm nuts they would probably fall off quite easily.
