208 shift pattern
Old Feb 13, 2004 | 07:10 PM
FordWheelin's Avatar
FordWheelin
208 shift pattern
I just bought a '86 F-150 4x4. It's me first Fargin Old Rebuilt Dodge, so this is prolly a moronic question, but cant find the answer anywhere
What is the 4x4 shift pattern for the NP 208?
I get 2hi all the way back and 4hi all the way forward and don't feel any 4lo or neutral....I assume it has a 4lo and a neutral gear...or am I wrong? If I'm right, is there a shift right or left in the pattern, or is it a straight shift pattern? If it's a straight shift pattern, has anyone encountered this problem and found a possible remedy?
I was planning on doing a rebuild for the tranny as it's leaking like a sieve out of virtually every seal in the case...was also gonna replace the bearings, but is there anything I might want to replace while I'm in there? shift forks, linkage rods, etc.?
Thanx heaps
Old Feb 13, 2004 | 07:42 PM
wildjon300ci's Avatar
wildjon300ci
Only thing I can help on is the shift pattern...which is 2hi-4hi-Neutral-4low That order is front to back.
Old Feb 13, 2004 | 07:55 PM
Lobuck76's Avatar
Lobuck76
And same if it's bw 1345
Old Feb 13, 2004 | 08:17 PM
MustangGT221's Avatar
MustangGT221
Moved to appropriate forum.
jfon101231
Feb 20, 2016 09:19 AM
Rvenhuiz
23
Jan 28, 2016 08:22 AM
Greg5OH
Jul 21, 2014 10:29 PM
magyar02
1983 - 2012 Ranger & B-Series
Jul 6, 2014 01:59 PM
Thunderhorn
1978 - 1996 Big Bronco
Jun 24, 2014 10:36 PM
