Transmission service
Old Feb 13, 2004 | 04:54 PM
Black88GT's Avatar
Black88GT
Its time for the service on the transmission. Do I need to replace the filter? I called oil changers, and they told me its 49.99 to drain and flush the transmission. Is that good enough?
Last week I asked one mechanic, and he told me 179. and that was to change the filter. Which route should I go? The truck has 56,000 miles. Thanks for the help
Old Feb 13, 2004 | 07:16 PM
buzzard's Avatar
buzzard
Definitely change the filter and make sure you/they drain the torque converter.....you should have to refill with ~14 qts. I did mine myself and parts alone cost around $65 so I don't know what you're getting for $49.99.
Old Feb 13, 2004 | 07:22 PM
Monsta's Avatar
Monsta
Sit. Stay.
Actually Ford says you do not need to change the filter as a regular maintenance item.
However, I changed mine on the first change and would probably do it every other. For no other reason than to say I did...
Old Feb 13, 2004 | 09:26 PM
99expyTN's Avatar
99expyTN
I'm servicing my transmission tomorrow (2/14). This will be my first time to do it myself (I hope some of you guys are monitoring the forum in case I have a question . I bought a new filter for $30 (and a new gasket for $20....just in case I mess the reuseable one up). The most painful purchase was 18 quarts of Mobil 1 synthetic at $4.99 a quart (ouch...that hurt). I also have a Nordskog temperature sender to install in the inspection port.
If anyone sees a loud HELP in the forum tomorrow, please respond quickly
Philip
Old Feb 13, 2004 | 09:35 PM
Black88GT's Avatar
Black88GT
Shoot, I wouldnt even know where to start if I were to do it myself. I think Im goint to go with the filter change route. Thanks for all the help guys. I dont know about the synthetics though.... Thats a little too much money for me.
Old Feb 13, 2004 | 09:46 PM
99expyTN's Avatar
99expyTN
I'm going to tell my wife that instead of candy and roses for Valentine's day, I got her something unique.....synthetic transmission fluid. Do you think that will go over well?
Philip
Old Feb 13, 2004 | 11:51 PM
Black88GT's Avatar
Black88GT
Philip
Well I just told my wife, and she said if I did that, I'd be packing my clothes in the expy when I was done
Old Feb 13, 2004 | 11:54 PM
buzzard's Avatar
buzzard
Philip
It's red, isn't it????
Old Feb 14, 2004 | 07:05 AM
99expyTN's Avatar
99expyTN
Buzzard, I like your logic.
Philip
Old Feb 14, 2004 | 09:46 AM
buzzard's Avatar
buzzard
Philip
Candy and roses are way overrated. The candy will just make her, errr fat, and the roses are already dead. My philosophy is to get her something that will last. This year was a new griddle (not girdle ).
Old Feb 14, 2004 | 09:53 AM
Frizzle's Avatar
Frizzle
Roses are Red, Voilets are Blue
Some Mobile Synthetic ATF is what I got for YOU!
haha
Old Feb 14, 2004 | 04:29 PM
99expyTN's Avatar
99expyTN
I just finished servicing my transmission. Here's what I did:
drain and drop the pan
replace transmission filter (next time remember to keep bucket under transmission)
clean transmission pan including magnet (really nasty)
drain torque converter (drains really slooooow)
reinstall plug on troque converter
reinstall transmission pan
torque everything to specs
remove inspection port and install temp. sending unit for gauge
add six quarts of ATF (Mobil 1 synthetic)
spend next hour with truck idling while adding ATF @ 1/2 quart shots
It took 14.5 quarts to bring it to the 1/2 way mark in the hot region of the dipstick. So far, nothing seems to be leaking.
BTW, The test drive was to the store to get my wife something for Valentine's Day. I didn't think the Mobil 1 synthetic would go over well.
Philip
Old Feb 14, 2004 | 04:44 PM
Black88GT's Avatar
Black88GT
Philip
Thanks for the info, I might tackle that next weekend. I wonder if it the same amount for the 4.6?
Old Feb 14, 2004 | 05:52 PM
99expyTN's Avatar
99expyTN
The amount depends on the transmission.
13.2 quarts for 4R70W and 16.4 quarts for the E4OD/4R100.
Check the transmission code on the drivers side door. 'E' means you have the E4OD/4R100 while 'U' stands for the 4R70W.
Philip
Old Feb 14, 2004 | 09:04 PM
pounder90's Avatar
pounder90
Check your dipstick. Mobil 1 ATF is not Mercon V rated. From Mobil 1's website:
Specifications & Approvals
Mobil 1 Synthetic ATF has the following builder approvals:
Allison C-4
Ford Mercon
General Motors Dexron III
swagfu
18
Mar 29, 2017 03:52 PM
FL SuperDuty
Mar 2, 2016 08:43 PM
jayhawk714
Oct 31, 2014 11:12 AM
scelogistics
Mar 4, 2014 08:10 PM
afreemanmd
Oct 20, 2006 04:46 PM
