Offroad & 4x4
Steering system
Old Feb 13, 2004 | 03:38 PM
fordboy1973's Avatar
fordboy1973
Steering system
I have a 1973 highboy and it has manual steering i was looking at putting power steering in because i have 36's right now and am going to be going much bigger in the future and it sucks turning. What type of system do you guys recommend and what parts am i going to need. This will be the first time i will try it and i want to get all the parts soon, so it will be ready for summer mudding season. Thanks
Old Feb 14, 2004 | 09:38 AM
78fordman's Avatar
78fordman
I would try to find power assist from that year, that would be the easiest, correct me if i am wrong, but 78-9 was the first year of true power steering, not just power assist. You could go with a setup from the late 70's, some custom work would probably need to be done.
Old Feb 14, 2004 | 10:31 PM
fordboy1973
what about that cross over steering system will that work and if it will what parts am i going to need.
Old Feb 15, 2004 | 12:20 PM
proeliator's Avatar
proeliator
check this out:
https://www.ford-trucks.com/articles/2003/23.php
Old Feb 18, 2004 | 05:37 PM
fordboy1973
I looked at the post and it seems very difficult to do is this the only way or is there an easier one to do?
Old Feb 18, 2004 | 08:06 PM
red_rocket's Avatar
red_rocket
The BEST and easiest way to do it is to adapt a pre78' 2wd steering box onto it. it requires some new holes to be drilled, and you have to cut off the end of the highboy pitman arm, and weld it to the 2wd one, but it's not too hard. When it's all said and done, you end up with a very nice, and very powerfull power steering.
Old Feb 18, 2004 | 08:07 PM
red_rocket's Avatar
red_rocket
doh.. Just looked at the write up, and thats exactly what it says.
Old Feb 18, 2004 | 08:28 PM
proeliator's Avatar
proeliator
Theres a guy on ebay who sells complete kits to do this to, you just bolt it all up. Would be easier if the task seems a bit much for you, but more expensive of course. You'd have to search on ebay to find it, don't have a link handy...
