di-electric grease
Old Feb 13, 2004 | 12:37 PM
Lcashmer's Avatar
Lcashmer
Question di-electric grease
Do you guys use di-electric grease on your plug wire connections?
Plug end? Ignition end? Both?
Old Feb 13, 2004 | 01:16 PM
BrianA's Avatar
BrianA
I used in on both ends of the plug wires.
Old Feb 14, 2004 | 12:24 PM
MJEmerson's Avatar
MJEmerson
same here
Old Feb 14, 2004 | 06:38 PM
b2_tim's Avatar
b2_tim
Always
I use it on my lights, plugs, wires, boots, and hair.
Well maybe not the last. But I do a lot of off-road and it helps seal out water and prevent corosion
Old Feb 15, 2004 | 11:18 AM
Drizzt's Avatar
Drizzt
IAW b2_tim i use it on everything, its not going to hurt anything and it may prove to be a life saver if you used it somewhere where you don't have to replace the part for 10 years (like a fan resistor) and it isn't welded together because you used the grease
Old Feb 15, 2004 | 08:38 PM
Bob Ayers's Avatar
Bob Ayers
I use it on the rubber boots on both ends of the plug wires.
Old Feb 17, 2004 | 02:02 PM
travlnman's Avatar
travlnman
I see a consensus here. Yep me too, both ends.
Robs06SuperDuty
Jul 16, 2013 12:33 PM
kermmydog
Mar 13, 2013 03:01 PM
drjoe171
Nov 13, 2010 08:44 AM
four-sixty-power
General Automotive Discussion
20
Sep 14, 2006 09:34 AM
jcandrew
3.0L V6
Jun 16, 2003 09:26 PM
