I have a 80 F-100 that used to have a 302. I went with a 300-I6 had to get mount plates for the 6. I left the org. motor mount plates the 302 had in place. The oil filter would have hit the drivers side mount plate if I didn't luck up and get from my buddy a 90 degree oil filter adapter that turns the filter down to clear the plate. This is what the two round gaskets you get in a kit fit. Before I got the adapter I wondered what they went to. This adapter makes for a cleaner engine at oil changes also you can pre fill with oil before you screw on filter.
