greenhighboy
Old Feb 12, 2004 | 09:24 PM
Thomsen's Avatar
Thomsen
greenhighboy
As you already know i am in the process of putting a 460 in my 70 highboy. I have a question regarding the clutch linkage. on the 360 the fork pivot was bolted to the block of the 360...where will i bolt this so that it will work with the 460. Thanks much:]
Old Feb 12, 2004 | 09:55 PM
greenhighboy's Avatar
greenhighboy
There is a similar bracket that bolts on with the bellhousing bolts behind the bellhousing. Its not avalible from Ford anymore so check the boneyards. Ask for one for 400-351M.
