71 F250 Payload
Old Feb 12, 2004 | 04:34 PM
dhglaser's Avatar
dhglaser
71 F250 Payload
What is the payload of a 71 F250? The tag on the door pillar does not have this information - it is blank.
-David
Old Feb 12, 2004 | 04:45 PM
BB's Avatar
BB
Is the whole door tag blank?
What about the middle which starts with the wheelbase, what are the codes there? Look for a F250, F251, F252 etc. See this thread as an example:
http://www.ford-truck.com/forums/sho...hreadid=200932
Old Feb 12, 2004 | 05:10 PM
dhglaser's Avatar
dhglaser
The tag on the door pillar is entirely blank except for the vin and a statement that the truck confirms to emiisions control standards.
On the door itself is a tag that has a bunch of numbers stamped on it. The lables above each number are unreadable however, this is how that stamped tag reads
131 6 F250 B 4 G 38
07500 170 4100 71
Is this of any help?
Old Feb 12, 2004 | 05:27 PM
BB's Avatar
BB
That's it! The Gross Vehicle Weight (GVW) is 7,500lbs, now if you just knew how much it weighed.
I've got some recommended payloads at home and can look them up later tonight if someone doesn't respond sooner.
Barry
Old Feb 12, 2004 | 05:33 PM
dhglaser's Avatar
dhglaser
I had the truck weighed, the empty weight is 5240 lbs. So that means the payload is 2260. Hmm, I thought this was a 3/4 ton pickup, not a 1 ton pickup.
Old Feb 12, 2004 | 05:37 PM
BB's Avatar
BB
That's the way they are. I've had over 2 tons in the back of mine and still had spring travel, the tires didn't like it though. I'll look up what Ford reconmmends for payloads tonight.
Old Feb 12, 2004 | 09:14 PM
willowbilly3's Avatar
willowbilly3
Fords payloads can be grossly exceeded if done only occasionally. I have hauled full cords of green birch on my 72 and it only has the 6200 gvw. I still had rear spring travel but I did bottom out a few times getting out of the woods. The terms 1/2 ton 3/4 ton ect. were probably coined a half century or more ago when those numbers may have been more accurate. Now they are just a generic term that indicates what model you have. 1/2 ton F-100 and F-150, 3/4 ton F-250 and one ton F-350. Interesting to note is that the GVW overlapped on the 3/4 ton and one ton in some years. Also some people still want to call the F-150 a 5/8 ton but the name never really caught on
Old Feb 12, 2004 | 09:29 PM
dhglaser's Avatar
dhglaser
What I was actually looking for is how heavy of a trailer I could tow. I'm thinking of getting a trailer equiped with electric trailer brakes and I was tyring to figure out the maximum tongue weight.
Old Feb 12, 2004 | 11:28 PM
BB's Avatar
BB
Hmmm... whatever the hitch can handle?
I was gonna scan the '71 brochure but to save Ken's storage space here's a link to the page you're interested in for payloads:
http://www.bumpsides.com/71lit/16.jpg
Old Feb 12, 2004 | 11:41 PM
Fritolay's Avatar
Fritolay
i have a 72 f100 i have pulled a 32 foot camper with about a 1000 lb tongue weight it was a bumper hitch but we converted it to a goose neck,
the truck also pulled a 20foot gooseneck with about 14000 pounds of hay piled on it. (smelled a little bit of burnt clutch to get it moving but it pulled it on a stock 360)
Old Feb 13, 2004 | 05:49 AM
averagef250's Avatar
averagef250
Pretty much the rule for any old truck is whatever you can put in the bed. When my truck was a flatbed I hauled a complete 855 cummins and transmission in the bed. It was the first time I'd hit the overloads, but hauled it like a champ. It weighed in at 13,800. We had a 53 GMC 3800 dually on the farm when I was a kid. Had a transplanted 302 jimmy and 5 speed with 5.13 gears. Now that truck would haul anything even if it wouldn't fit in the bed.
Old Feb 14, 2004 | 12:21 AM
Fritolay's Avatar
Fritolay
basiclly if the pumpkin aint on the ground these trucks can take it
sometimes they will take it even if they are on, in or under the ground
Old Feb 14, 2004 | 01:58 AM
willowbilly3
When I was a kid my dad had a 59 chevy 1/2 ton. He routinely hauled such large loads that it would split the rims open occasionally. It wasn't at all uncommon to haul 2 large saddle horses in the back, or a full load of gravel.
Old Feb 14, 2004 | 04:55 AM
ken's1971's Avatar
ken's1971
my friend use to load his pickup till the suspension bottomed out, but one time his tire blew he almost flew out of control. Now he does'nt do that and i won't either
