4x4 Vibration
Old Feb 11, 2004 | 07:49 PM
ttaj's Avatar
ttaj
4x4 Vibration
Has anybody experienced a vibration in the floor board when the truck is in 4 wheel drive? The truck has manual hubs, only vibrates when the transfer case is in 4x and hubs are locked. It does not do it with the hubs locked and transfer case in 2x.
Truck is '04 f-350 6 spd 4x4, it feels like there is a bad u-joint in the driveshaft somewhere. Any help or experience would be greatly appreciated.
Old Feb 16, 2004 | 06:54 AM
AlaskaPowerStroke's Avatar
AlaskaPowerStroke
Question
ttaj
I have a decent amount of experience with 4x4s, mostly older ones, though. What speeds does it vibrate? Does it go away when you go faster or slower or when turning or driving straight? Rough terrain? If it was a driveshaft ujoint it should vibrate any time the hubs are locked in, whether 2x or 4x. Once the hubs are locked in that turns the axles which in turn, turns the driveshaft. Possibly within the t-case. But I am not for sure. Some things like that are hard to diagnose unless a person is actually there. Maybe put it up on jack stands and have someone run it slow in 4x and 2x and see if you notice anything out of the ordinary. The best thing I can tell you is take it to the dealership since it is under warrany. Wish I could help you out more.
Old Feb 16, 2004 | 05:25 PM
ttaj's Avatar
ttaj
It is going to dealer tuesday for noise, leaky rear main seal, limited slip diff set up too lose and leaking oil from left front hub.
I will let you know what they find out.
