Carb/timing issues
Old Feb 11, 2004 | 06:12 PM
brennamp's Avatar
brennamp
Carb/timing issues
I have 79 F250 with a 460 in it. I have a holley 750 on it, and the timing is set to 10 BTC. I have been trying to adjust the carb but it still creates a popping noise as I press down on the accelerator. Its coming from the carb. Does my timing need to be increased? I call the ford dealership and the book says 8 BTC but I have heard to run them at 12. Is that the problem, or is the 750 too big for the motor. It has a dual plane intake. Another question is could it not be getting enough backpressure cause the problem?
MIKE
Old Feb 11, 2004 | 07:21 PM
olfordsnstone's Avatar
olfordsnstone
Could be accelerator pump.
edit: welcome aboard at FTE!
Old Feb 11, 2004 | 11:20 PM
FordPickup460's Avatar
FordPickup460
I just put a slealth intake and a 750 edelbrock on my 84 460 motor, and timed at 8 it would backfire through the carb. i advanced the timing to 10 and it ran better and the back fire stopped. i am thinking about trying it at 12.
Old Feb 11, 2004 | 11:21 PM
76390FE's Avatar
76390FE
You could try turning out the idle mixture screws a bit...maybe it is running a little lean...
Old Feb 11, 2004 | 11:43 PM
Icicle's Avatar
Icicle
Doesnt an intake valve HAVE to be opened in order for an engine to backfire through a carb?
captain1997
Apr 6, 2013 12:54 PM
JNeptune
May 18, 2009 07:55 PM
lattices2
1978 - 1996 Big Bronco
Oct 4, 2005 01:17 PM
ghm
Jun 7, 2004 06:49 PM
jopey
Sep 27, 2000 08:45 PM
