A4LD torque converter troubles ... HELP!!
I posted this in the transmission forum also, but I wanted to see if any of you regulars in the Ranger forum would have any advice;"""Hello all ... I am new to the transmission forum ... I usually hang out in the RANGER forum. But, I have a serious problem with my Ranger tranny, NEED HELP NOW!! It is a 1985 2.8 V6 2WD with A4LD tranny. I wrote a letter to a friend, but I would like to get some input from a few experts in this forum also. The letter is as follows;
Hey Rob,
Do you remember me?? I'm amp17757 from the Ranger FTE forum. You and I communicated about a year ago about the A4LD. I am in a desperate situation, and was hoping to be able to "PICK YOUR BRAIN ONE AGAIN"! PLEASE REPLY ROB!!!
As you know, these things have a lock-up torque converter. As I understand it, the lock-up mechanism is not activated unless and until the transmission shifts into 4th gear. My tranny has been defective from the get-go (bought it in Dec 1999, no 4th gear, no lock-up). But the first 3 gears have worked fine all this time. Now, all of a sudden, out of the blue, my torque converter has decided to lock up, but it won't unlock! I was driving home from work last night, and it locked up, and as I came to a stop, it wouldn't unlock. It stalled the engine. It was a miracle I made it home. This morning, I drove it to work, because I pretty much had no other choice. It was STILL LOCKED UP THIS MORNING! I managed to get it going, since I live on a hill ... I was able to drift a little before shifting into gear. I drive 15 minutes to get to work. I was praying passionately to The Lord that I would not have to stop anywhere, or I might not get going again. My prayers were answered, I didn't have to stop anywhere. As I pulled into the parking lot, I noticed that the TQ had finally UNLOCKED! I was able to park my truck in a space on an incline, so that in case it does this again, I can coast out of the space before shifting into gear.
I desperately need to know TWO THINGS;
FIRST - I know that there is an electrical connector that triggers the lock-up mechanism ... PLEASE TELL ME EXACTLY WHERE THIS CONNECTOR IS, SO THAT I CAN DISCONNECT IT!!
SECOND - Is there any remote possibility that this thing locked up due to a MECHANICAL failure, rather than an electrical or electronic failure?? Is it possible for it to lock and unlock arbitrarily even with the connector removed??
I am in a desperate situation Rob. Any light you could shed on the subject would be GREATLY APPRECIATED!! THANK YOU SO VERY MUCH IN ADVANCE BUD!!
SINCERELY,
Mike"""
What do yall think??? PLEASE HELP ME!!!!
In short, bite the bullet and take your truck in.
1. If the torque converter clutch solenoid valve does not exhaust, check the torque converter solenoid valve.
2. If the converter clutch valve is stuck in apply position, check the control valve assembly.
3. If there is a missing screen that allows foreign material to stick the torque converter clutch solenoid ON, check the torque converter clutch screen and replace as necessary.
4. If there is no unlock signal, the bypass solenoid is damaged or inoperative, or the bulkhead connector wires are damaged; check the electronic engine control or transaxle electrical system.
After reading all that (It's Greek to me too), try one plug at a time. There can't be more than 3 or 4 (Boy I'm being optimistic here). Good luck and keep us posted! I would think that a solenoid would be mounted externally, but really can't promise that it is.
i have a question that I thought you might be able to help me with. I have a ranger myself, and i seem to be having trouble with the left front splice assembly, and was wondering if you think that it is a skiving problem, or hertzian stress??
Thanks
Phillup de Cube
Since we are talking ELECTRICAL SPLICES, (as opposed to fiber optic splices), I would suspect that Hertzian stress impressions are NOT your problem. HOWEVER! I can see where SKIVE could definitely be your problem ... material gets skived up, gets lodged between the connections, causing an open circuit. Does anyone else have any wisdom to offer???
