Instument Gauges quit
Old Feb 11, 2004 | 11:49 AM
Haakeyez50's Avatar
Haakeyez50
Haakeye wrote:
I live In Canada Alberta Edmonton area. I have had my Guages quit on the right side of the dash. Only when it is good and cold and I am travilling on the Highway about 110km or so speed wise. It will do it five miles down the road or so, sometimes they come on again but mostly stay off. The tack quits, the water temp, and the trans temp. The check engine light comes on when these gauges quit. I than let the truck sit at work or home shut off for awhile and every thing is normal. The truck does not quit when this happens and as long as I don't go fast on the highway it won't do it. Happened last year 2003 Feb. and now in 2004 winter never had a problem in summer. I had mentioned it to my dealer last year but it was not a big concern to me at that time. Just trying to find out if more are having that problem. Other than that love my truck. I even have air bags for suspention all four corners.
03 F350 4x4 Lariat Crew Cab Dually LB
Build date 01/03
Ordered/ Purchased 02/12/02 @ 0 km.on Odometer
Issue: 03/19/03 truck quit or stalled, Gauges quit
Odometer when Problem noticed: Approx 2749 km
Initial Fuel MPG: 17.2 mpg by counsel
Repair was ICP sensor installed and computor flash programed the FICM, PCM,& trans controler Moduel to lastest Calibration.
Engine fine @ Odometer 23000 km. Truck great
Had lastest flash done in October 2004
10/10 FLASH @ Odometer 23995 km.
Current MPG: Avg. 15.2 MPG by counsel
Current Odometer 34053 km.@ 2004/02/11
Guages quit in cold 2004/02/02 and truck runs fine
