spark plug gap
Old Feb 11, 2004 | 09:06 AM
steeldust's Avatar
steeldust
spark plug gap
hi there all. as an ignition gets older should i narrow the spark plug gap? i have a 78 f-250 400cid stock electronic igniton. the coil is new but the dist. and module are at least 15 yrs old.
Old Feb 11, 2004 | 01:18 PM
gasman6674's Avatar
gasman6674
The coil is the juice the module is the switch so I vote no unless your running a large gap for ex. .060 then I would drop it to .045 or so but thats personal opinon
Old Feb 12, 2004 | 04:13 AM
Mike W's Avatar
Mike W
Too large a gap can cause crossfire. I would keep the stock settings.
Old Feb 12, 2004 | 09:39 PM
Franklin2's Avatar
Franklin2
There are no moving parts in the electronic ignition except the dist shaft, and the breaker plate. Grab the rotor and wiggle it back and forth to check the bushings. Wiggle the plate around where the vacuum advance arm hooks. If everything looks ok, the system is still 100%, no matter how old it is.
