1978 - 1996 Big Bronco
Bronco Engine Pics
Old Feb 11, 2004 | 05:45 PM
ALSAIR's Avatar
ALSAIR
Hey COBRAjrb go to this site and read the forum, some other guy's have posted there asking the same questions, or it may be you, I don't know-www.network54.com/forum/119417
The guy's over there are all small block ford guy's. They helped me with my re-build.
She Ain't Revved Ti'll The Rods Are Thrown!
Al
Old Feb 11, 2004 | 08:14 PM
{OF}Smiley's Avatar
{OF}Smiley
Here is a pic of something close to a 500 hp 5.8
Supercharged and Modified 351W – 460HP est.
Bored .030 over, Ross forged pistons, Eagle rods
World Products Sportsman II heads - valves: 2.02 intake, 1.60 exhaust - ported & polished
Kenne Bell TS3000-8 Supercharger Kit (WhippleCharger) - 8 psi boost
Bronco for sale
Old Feb 11, 2004 | 08:44 PM
ohrtman19's Avatar
ohrtman19
how much you got into that 5.8 smiley????
Old Feb 11, 2004 | 10:54 PM
COBRAjrb's Avatar
COBRAjrb
Thumbs up cool
hey man thats a badass engine looks great. how much did u put into the engine? and about whats the gas milage your geting on it. im trying to decide to go carb or rebuild the 5.8 efi. if the efi is considerly better gas milage i would probaly have to go with rebuilding. but if if its about the same i would defintely go carb i think there real cool. im thinkin 460 carb about 500hp :X06\m/ again man real nice engine
Old Feb 11, 2004 | 11:08 PM
COBRAjrb's Avatar
COBRAjrb
http://www.fordcobraengines.com/460_500lbs..htm ive posted this before but this is what i have in mind for my bronco. if i decide to go with a carb engine check out that yellow classic yellow bronco in there.
Old Feb 12, 2004 | 01:17 AM
justshootme84's Avatar
justshootme84
Supercharger!!!
All I have is a 351W H.O. with an Edelbrock Performere intake, Holley 4 bbl. Reported to have 235HP. Oh yeah, and my custom-made shaker!!!
Old Feb 12, 2004 | 06:36 AM
{OF}Smiley's Avatar
{OF}Smiley
I've got about $8500 into just the engine. I stayed with a small block because everyone goes big block, I wanted to be different than all the other fast Broncos at Silver Lake dunes. The main Bronco I wanted to beat was one with a 429 Cobrajet in it. I was just slightly faster in a sand drag, but the small block won for me
I stayed with EFI because it is not affected by the camber of climbing the dune faces. I've watched many a strong truck die on the hills because the float bowls of their carbs flooded out the engine. It would have been cheaper without the EFI issues, it should still be converted to MAF instead of speed density to get the most out of that engine.
Of course having that much torque the tranny needed to be built up, twice. And I had to go with a Dana 60 in the rear so the gears would stop tearing off teeth.
Now I'm selling the Bronco, moving on to other trucks after 10 years.
Old Feb 12, 2004 | 02:56 PM
COBRAjrb's Avatar
COBRAjrb
Thumbs up
what are your times on that engine? 1/4 mile..... 0-60 in that beast?
Old Feb 12, 2004 | 03:20 PM
ALSAIR's Avatar
ALSAIR
Paint is all done. Never done this before let's see if they go!
Block- "89" .030 over
Cam- Comp Cams valve lift .462 int. .493 exh. duration 206/214
Pistons-Flat top hypertectic's 9.7 to 1 comp.
Heads-stock ported and polished with 1.54 exh & 1.84 int gasket matched all int & exhaust.
Timing chain- Comp Cams double roller
Push rods- Trick flow's 8.350
Rockers- Summit alum. rollers
Intake-Wieand Stealth
Oil Pump- High volume
Fuel system- holley commander 950 T.B.I.
Water pump-Undecided
Hopefully will be all done soon!
Al
Old Feb 12, 2004 | 05:00 PM
BroncoRoadKill's Avatar
BroncoRoadKill
I have heard from several engine guys around my area that aluminum rockers is the worst you could do too your valve train, due too it flexing and the brittleness of the material.
Not trying to start something, but what are you guys opinions on them, compared too steel rockers.
Old Feb 12, 2004 | 05:31 PM
ALSAIR's Avatar
ALSAIR
In a high revving engine, yes they are not good. It all depends on what your driving and how. I am not going down the quatermile and not running nitrious, and not going above 5000 R.P.M. and I don't have a monster cam putting a strain on the valve train. I would not put them in a pro-street car, but in my bronco they will be fine!
Al
Old Feb 12, 2004 | 11:28 PM
DW2455's Avatar
DW2455
i had over 12000 miles on my built 351 cleavland in my torino before i sold it, it was a daily driver and had crane aluminum roller rockers on it with no problems, last i heard it was still running. DW
Old Feb 12, 2004 | 11:58 PM
  #28
xKirkx's Avatar
xKirkx
what year was that torino i love those beasts especially the 70 429scj
Old Feb 13, 2004 | 05:21 AM
  #29
DW2455's Avatar
DW2455
It was a 73' Torino sport (fast back) factory top loader 4spd, ect. ect. DW
