Sponsored by: Real Truck
250/350 SD springs
Old Mar 22, 2002 | 09:23 AM
skipjack's Avatar
skipjack
250/350 SD springs
Good morning Moonst! I like what you did with your front end, cool! I was sitting next to a new '02 350SD yesterday, and we both noted his springs and mine ('01 250SD)look the same. How can you tell them apart? I've been thinking of upgrading, but what are the odds the boys in Kentucky accidentally did it for me? Thanks, Mike
Old Mar 22, 2002 | 03:15 PM
Monsta's Avatar
Monsta
Sit. Stay.
250/350 SD springs
Are you talkin' to me?? I'm monsta! Not moonst...
You should have spring codes on your door jamb label. Post the codes and we'll all tell you what you got.
Old Mar 22, 2002 | 03:31 PM
RE_SPEED_FAB's Avatar
RE_SPEED_FAB
250/350 SD springs
Yes its true, Monsta is the one in the....well let's just say, dressed different than most guys
But full of knowledge at any rate, and seems to have a great sence of humor, based on his previous posts.
SHAKE? ...... psych...
Old Mar 22, 2002 | 07:56 PM
skipjack's Avatar
skipjack
250/350 SD springs
Moonsta . . . Monsta ... My OOOps, sorry. The lower right side of the label says SPR with KB below it. The top of the label indicates I have the 8800# GVWR. I was just wondering if there was a chance I have one ton springs by mistake (to my favor). Mike
Old Mar 23, 2002 | 09:24 AM
NoMo's Avatar
NoMo
250/350 SD springs
There are no 'one-ton springs' per se. Each SD (F250 or F350) is built with front springs that are "computer selected" based on option packages and cab configuration. And, both models have the same spring selections to choose from. So, it's very possible to have an F350 with "lighter" front springs than an F250. Plus, all the springs look the same. For the most part, the only differences between them are the rate of deflection (ie. stiffness). We are talking about SRW trucks aren't we? :P
Old Mar 24, 2002 | 09:58 AM
skipjack's Avatar
skipjack
250/350 SD springs
Thanks NoMo. Yes, they are both SRW. We were looking at the rear springs. I'm going to have a Banks TransCommand installed next week, and thought I'd have a set of bags put on the rear end just for that extra "ounce of prevention." When I saw the springs on the new 350SD SRW looking just like mine, I wondered what the difference was. Figured it had to be something to get the GVWR up that additional 1800#. Thanks again, Mike
Old Mar 24, 2002 | 05:27 PM
Monsta's Avatar
Monsta
Sit. Stay.
250/350 SD springs
Man this whole time I thought you were talking about the FRONT springs. My manual didn't cover the code that you mentioned. I'm running all over looking for the answer but it's Sunday...Unless you got a micrometer, you won't notice the difference between the 250 & 350 rear springs. But there is one.
Old Mar 25, 2002 | 10:41 AM
NoMo's Avatar
NoMo
250/350 SD springs
I also thought we were talking about front springs. But the info holds true for the rear springs too. Take a look at the specs: www.fordtraining.com
Old Mar 25, 2002 | 12:17 PM
redranger1's Avatar
redranger1
250/350 SD springs
