Temp guage not working
Old Feb 10, 2004 | 09:20 PM
hbronco's Avatar
hbronco
Unhappy Temp guage not working
My aftermarket temp guage is not working anymore.
Today i put in a new thermostat, coolant, but my guage just does not want to work.
It seems to be connected up right, could the guage be bad?
Thanks
Old Feb 10, 2004 | 10:18 PM
Ultramagdan's Avatar
Ultramagdan
Gauge is possibly bad or sensor has lost it's ground. I would check the sensor and the gauge.
Old Feb 10, 2004 | 11:00 PM
hbronco's Avatar
hbronco
I checked the ground, it seems good to me, can the sending unit that houses at the top of the thermostat cover go bad? When i had it off it looked ok.
Ill check the ground again tomorrow, when you buy a temp guage do you get all the wires and sending unit for it?
Thanks
Old Feb 11, 2004 | 02:26 PM
hbronco's Avatar
hbronco
I redid the ground wire today, and the guage still is not working, so im thinking the guage has died, unless the sending unit in the thermostat housing is shot somehow, but i dont think that is the case, will most likely replace the guage.
Thanks
Old Feb 15, 2004 | 02:52 PM
Beast12's Avatar
Beast12
You can test your temp gauge by unhooking it from the sender. Then get someone to turn the key forward while you get the wire and ground it. If your gauge goes up to hot then you should be good. Do not leave it grounded for a long time because you can wreck the gauge. Good luck.
-Matt
P.S. Sending units are cheap and easier to replace so you may just want to change that too.
Old Feb 20, 2004 | 05:36 PM
hbronco's Avatar
hbronco
I replaced the entire gauge, and all is well, thanks!
philv
Jan 1, 2017 10:31 AM
fordrocks96
Nov 8, 2015 02:31 PM
Bbasso
Oct 10, 2015 03:55 PM
cabinman
Jun 30, 2015 08:36 PM
jreilly57
Nov 9, 2006 10:00 AM
