Sponsored by: Real Truck
Back Spacing
Old Feb 10, 2004 | 07:51 PM
Chops's Avatar
Chops
Question Back Spacing
First post- hope you guys can help!
I have an 02 F250 4x4 SRW 5.4 w/ X springs. I'm upgrading wheels and tires to and DO NOT want tires sticking out of the fenders (much). I'm really tired of seeing trucks that look great from the side and rediculous from the rear. I'm convinced if I buy wheels with a higher back spacing, more like 5 1/2 as opposed to 4 1/2, I can tuck the tires in enough to look right. Trouble is the only wheel I can find with a BS over 4 1/2 is the AR Outlaw II (5 1/2), which I'm fine with but the design's a little dated. I'm going to use 16x8's with 315/75's or 35 12.5's. Lift is all set.
Are there any other wheels out there with 5+ BS???
Thanks to all in advance!!
Chops
Old Feb 10, 2004 | 09:47 PM
mrwizard's Avatar
mrwizard
I would bet you will run into problems with the front tires rubbing if you try using that much backspacing.
Old Feb 11, 2004 | 06:25 AM
Chops's Avatar
Chops
How much backspacing could be used for 12.5's? 4 1/2 seems to be the average. I'd like to go with at least 5 ???
Old Feb 11, 2004 | 07:11 PM
CAT_man_963's Avatar
CAT_man_963
Stick with 8" wide wheels instead of 10" - and keep the backspacing CLOSE to stock - that should keep the tires in the fenders - i'm sure i read somewhere that the superdutys are prone to rubbing the springs with the wrong spacing - my suggestion anyway
mrseventhree
Feb 11, 2015 09:11 PM
stal94gt
Feb 22, 2013 07:37 AM
DarrellJ
Apr 10, 2011 06:48 PM
corey fletcher
Oct 15, 2010 05:32 PM
