Sponsored by: Kumho
Explain Tire sizes to me!
Old Feb 10, 2004 | 06:33 PM
Truckboy's Avatar
Truckboy
Question Explain Tire sizes to me!
Okay so I am a newbie with no clue about what I am looking at. After owning cars all my life I pretty much understand the whole MM percentage ratio thing with car tires or the whole 275/75R16 measurement deal. Now that I own a real truck, can someone take a moment to explain real truck tire dimensioning? I mean the whole 33 X 12.5 stuff. I am assuming that this is real American measurements of the heigth and width of the tire but I am not sure. Or could you refer me to a good website that can? I would really appreciate it. It would be nice to understand this. Thanks
Old Feb 10, 2004 | 06:45 PM
xlt70black's Avatar
xlt70black
TIRE SIZE
275 is the width in metric measure
75 is the height of the sidewall wich is 75% of the width
and 16 is no doubt the rim size.
Old Feb 10, 2004 | 07:11 PM
Truckboy's Avatar
Truckboy
Thanks but as I said I understand that. What I need to know is what is the definition of the other types of truck tire measurements such as 33X12.5. Is this standard measurements? What are the standard size ranges for this dimensioning?
Old Feb 10, 2004 | 07:28 PM
Opiewan's Avatar
Opiewan
well my 33x12.5 were 12.5 inchs wide and i am pretty sure they were 33 inchs tall. they were mounted on 16.5 inch rims. does that help ?
Old Feb 10, 2004 | 07:32 PM
71and72F100s's Avatar
71and72F100s
Hi
The 33" is a close number to the actual height, 12.50 means from the edge of the wheel to middle of the tread.
Old Feb 10, 2004 | 07:41 PM
Truckboy's Avatar
Truckboy
Yeah okay so it is in standard inches. I was still not sure about the whole width thing. I will have to measure my tires to see if it is to the middle of the tire. I found a website that I am not done reading that seems to have some pretty good info explaining truck tires.
http://www.tiresafety.com/size_class/size_nav4b.htm
Thanks everyone! Once again you really came through in a hurry!
Old Feb 11, 2004 | 01:14 PM
Boss50's Avatar
Boss50
Doesn't it mean the width from bead to bead on the tire?
Old Feb 11, 2004 | 07:09 PM
SoCalDesertRider's Avatar
SoCalDesertRider
It is the overall width of the tread, as I understand it. If it was from the edge of the wheel to the middle of the tread, your wheels would be two feet wide!! The distance from bead to bead will vary depending on what size rim you have them mounted on. Typically a 12.50" wide tire is mounted on a 10" wide wheel. Yes, all measurements are made in Standard (inches).
33x12.50-15LT The first number is diameter. Second width. Last, rim diameter. LT stands for Light Truck. Where you find a 'C', 'D', or 'E', that is the load range, or weight-carrying rating of the tire.
Old Feb 11, 2004 | 08:54 PM
Opiewan's Avatar
Opiewan
isnt that what i said 2 days ago ?
my tire is 33 inchs tall, my tread is 12.5 inchs wide
and i running 16.5 inch rims
33x12.5x16.5
Old Feb 12, 2004 | 09:28 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Originally posted by xlt70black
TIRE SIZE
I thought the 275 is the height and the 75 is the width.
Because when my dad got new tires for his truck he went from 235 to 255 and they were taller, they were both 75 16R
Old Feb 13, 2004 | 12:58 AM
mrwizard's Avatar
mrwizard
No, the first number (235, 255, etc...) is the width. The 75 is a percentage of the width, not a specific height measurement. They are taller because 75% of 255mm is more than 75% of 235mm.
Old Feb 20, 2004 | 06:34 AM
rlp's Avatar
rlp
Found this on the previously mentioned website:
Light Truck High Flotation:
31X10.50R15LT
31 Approx. Tire diameter in inches
10.50 Approx. Section width in inches
R Radial construction
15 Rim diameter in inches
LT Light Truck designation
SixPoppin'
19
Oct 16, 2016 11:35 PM
M-S-G
May 24, 2016 08:11 PM
Connor O'Brien
37
Dec 30, 2014 09:35 PM
2010F350
6.4L Power Stroke Diesel
Oct 17, 2010 04:36 PM
mgm415
Dec 25, 2002 05:25 PM
