Sponsored by: Real Truck
oil pressure sending unit
Old Mar 24, 2002 | 02:01 PM
Medic 13's Avatar
Medic 13
Old Mar 25, 2002 | 04:42 PM
usmc1775's Avatar
usmc1775
To make it short, I do not what to replace my factory sending unit and guage if possiable, I want to add a true oil pressure guage and sending unit. Where should I put the sending unit, I am going to use a pillar mount for the guage, but I do not know where to put the sending unit to get a true reading of the oil pressure.
USMC1775
2001 PSD CC 4x4
Old Mar 25, 2002 | 06:54 PM
powerstroker250's Avatar
powerstroker250
There is a plug on the oil filter housing you can use to tap in for the pressure gauge.
Les
Old Mar 25, 2002 | 07:25 PM
usmc1775's Avatar
usmc1775
You say that I can plug into my oil fliter housing, ok that brings up another question, the way it all goes together, I am mech inclined but what kind of sending unit should I use so to make sure it will fit the threads, and wont block the port if there is a chance of blocking it. Sorry for the uneducated questions but I really want a true guage but do not want to mess up anything in the process. Thank you so much for giveing me help, I am sure it wont be the last.
Thanks again,
Usmc1775
2001 PSD CC 4x4
Old Mar 26, 2002 | 02:54 PM
buffy's Avatar
buffy
Most (if not all) oil pressure guages come with a sender. All the senders that I've seen have a 1/8" pipe thread fitting. They usually come with adapters for other sizes.
