'79 351m Oil Gage Function?
Old Feb 10, 2004 | 05:27 PM
ERIC79XLT's Avatar
ERIC79XLT
Hey all,
Another stupid question from an inexperienced driveway mechanic in training. Where is it, and how does the factory oil pressure gage on a 1979 351M function? My gage starts off up at about the "A" in NORMAL when cold. (I understand that the viscosity is high when the oil is cold.) When the engine reaches normal operating temps the oil gage goes down to about the "N". (I understand that the viscocity goes down when the oil gets warm.)
I'm just curious where the gage lead is on the engine and how the gage works. Also, what might cause such a swing in my gage readings? Is this okay, or is my engine in trouble? Finally, what do most of you run for oil in an engine of this vintage? I live in Michigan and the coldest we usually see is -10's in the winter max.
By the way, the guy I bought the Bronco from claims the mileage is original. It at about 68,000 right now.
Thanks for any help!
Old Feb 10, 2004 | 05:59 PM
monsterbaby's Avatar
monsterbaby
first off factory gauges are notorisly inacurate, so if you really want to know put in a mech gauge but depending on your oil yes some flucation is normal although that sounds like alot but like I said the gauge maybe moving that much to show a 5lbs difference.
The sending unit is on the back of the block right behind the intake.
personally I like valvoline 10w-30 oil
Old Feb 10, 2004 | 11:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can read all about low hot oil pressure in many posts here.
Hook a mech gage up temporarily if you want to read actual pressures. Running an oil line into the cab can be a recipe for a dangerous mess, or a dead engine if the line ruptures in the engine compartment.
I like to run the factory electric gage with a set of temp and pressure switches hooked to a red "trouble" indicator light.
fordopie
Mar 29, 2012 09:08 AM
thedaddycat
Aug 1, 2007 09:48 AM
playbass48
1983 - 2012 Ranger & B-Series
Sep 16, 2006 04:56 PM
mich52
Dec 30, 2003 12:47 PM
milton
1997 - 2003 F150
Mar 13, 2003 07:10 PM
