Sponsored by: Auxito
98 F150 XLT Problem
Old Feb 9, 2004 | 08:41 PM
grunge09's Avatar
grunge09
98 F150 XLT Problem
Buddy of mine's 98 XLT F-150 died (his words), bought it off him. He said the motor was locked up. Also he says it has an interceptor motor in it. How do I tell that???
I cranked it over and it acts like it "jumped timing" It will crank and acts like it will almost start. No check engine light visible.
I got a Haynes manual on it. Seems that if the timing chain(s) are bad. Then according to the manual "I WILL have valve damage."
have I diagnosed right? Did I miss something simple stupid??
Would I be better off finding a wreck with a good motor or rebuild the existing motor??
Anyone got any ideas?? thanks in advance...
Old Feb 9, 2004 | 09:08 PM
98f1504x4ohio's Avatar
98f1504x4ohio
Does it have spark? That would be my first check. Also on the 98's the fuel pump has a shut off by the passenger's feet, on the exterior side. But to answer your main ? , If it were me, it would depend on the cost of each solution. If I had a guy that built engines cheap, I'd rebuild. If I knew a guy at a wrecking yard, and could get a good motor at a good price, I'd go that route for less downtime. I think you have to find an engine of the same model year, though.
Old Feb 9, 2004 | 09:40 PM
Ultramagdan's Avatar
Ultramagdan
Hello grunge09 and Welcome to FTE
Wow, a neat project. I have never heard of a interceptor motor in a F150. How many miles are on the motor?
If you have to replace the motor it is not a easy swap. The best way is to remove the cab from the frame and then remove the motor.
Old Feb 9, 2004 | 10:17 PM
LxMan1's Avatar
LxMan1
If it is the basic 4.6L or 5.4L, there is no Interceptor engine.
The police package has true duals and a little hotter set-up in the PCM programming. The engines are the same internally.
Jimmy
Old Feb 9, 2004 | 10:21 PM
grunge09's Avatar
grunge09
Re: 98 F-150 Problem
I'll start with the basics, check fuel, spark, hope its not in the valve timing.
1st I have to get it off the trailer and on the ground in the morning.
Anyone have an idea of how (on the motor itself) I can tell how many liters it is (and I am missing the top plastic cover that says that). Or what model heads (windsor, etc if I did my homework right).
Old Feb 9, 2004 | 10:25 PM
LxMan1's Avatar
LxMan1
Check the vin # if it is original
L= 5.4
W = 4.6
2 = 4.2v6
Old Feb 9, 2004 | 10:53 PM
PaulC's Avatar
PaulC
I think he means interference engine, not interceptor motor. By interference engine, I mean that the valves will crash into the pistons if the timing chain breaks.
Old Feb 9, 2004 | 10:55 PM
LxMan1's Avatar
LxMan1
HHMMMM, Hard to tell really.
Old Feb 10, 2004 | 12:10 AM
Racerguy's Avatar
Racerguy
Maybe he means its got PI heads. Some people figure that PI stands for Police Interceptor.
cookieharp
Apr 16, 2012 03:06 AM
Larrivee
Mar 24, 2011 12:54 AM
Crabby144
Apr 6, 2010 06:52 AM
micahman
Modular V8 (4.6L, 5.4L)
17
Dec 22, 2006 08:26 PM
steveh
Jul 28, 2004 06:26 PM
