1978 - 1996 Big Bronco
throttle body help
Old Feb 9, 2004 | 07:53 PM
crazed87bronco's Avatar
crazed87bronco
throttle body help
i have a question about throttle body's my bronco doesn't seem to be getting full throttle i just replaced the whole throttle cable with a brand new one and it hasn't changed i looked at the throttle body while my friend pressed on the gas the butterfly only opened about 50% i thought the butterfly was supposed to be completly straight
Old Feb 9, 2004 | 08:45 PM
bigric's Avatar
bigric
When the pedal is to the floor, the butterfly should be completely open. Is the pedal on the floor at the end of it's travel? Is there excessive slack in the cable when there's no pressure on the pedal?
Old Feb 9, 2004 | 08:50 PM
crazed87bronco
the pedal was completely to the floor when i looked and it was only open like i said about 50% of the way there isnt any slack on the cable but i can lift up the pedal alittle bit
Old Feb 9, 2004 | 09:15 PM
bigric's Avatar
bigric
How much is a little bit? I'm not sure if there's any adjustment point for removing slack.
Old Feb 9, 2004 | 09:17 PM
crazed87bronco
i can lift it up about a quarter to a half inch
Old Feb 10, 2004 | 12:06 PM
crazed87bronco
what can i do to get it to open to full throttle?
Old Feb 11, 2004 | 03:20 PM
Gooch's Avatar
Gooch
check the pedel itself, could possibly be bent not pulling the cable as far. just a thought.
mcd432
2004 - 2008 F150
Oct 24, 2012 08:14 AM
armeddoc
Aug 21, 2011 02:35 PM
John with beastly 302
Jan 7, 2009 08:06 AM
Quackhead94ranger
1983 - 2012 Ranger & B-Series
29
Jun 24, 2004 04:35 PM
wiggles
1997 - 2003 F150
Oct 28, 2003 02:22 PM
