Rear Drink Tray - 2001 Expedition
The drink holders collapse in half, so you may have to help them collapse as you are pushing the assembly up to close it. It has a positive engagement that is fairly robust, so you may need to work it a bit. Also, make sure there are no bottle caps, pencils, cap from the power point etc in there to block it from shutting. Good luck.
I had a similar problem with mine that was driving me nuts. After careful examination, I found that the left side of the mechanism that causes the cup holders to 'collapse' before folding had come unhinged, so the cup-holder wasn't collapsing and thus couldn't properly close. It would be worth a check.
