99 Expedition rear bags inflate but not front shocks
So new problem came up. Seems to not be your normal air suspension issue.
My back bags fill up just fine, but it seems that fronts don't fill at all. In fact my front bump stops are up against the frame.
Are there solenoids that can fail that prevent air from going in? Or do the solenoids only vent the air out?
Can is there a way to test the relay under the bumper to see if it has somehow failed? Or if it failed would all 4 corners be flat?
Only with the $3K dealer scan tool. You're stuck running power directly to the solenoid to test it. You can also test for power at the solenoid at it's pigtail. If there is power then you know the solenoid isn't working.
V8SHO
1997-2006 Expedition & Navigator
12-04-2016 12:22 PM
bward13
10-06-2013 01:01 PM
