Firing Order?
Old Feb 10, 2004 | 11:15 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can always grind a spot smooth and stamp it in with some number stamps. I always stamp blocks, intakes and heads etc with the machine operations done also for ref.
Old Feb 11, 2004 | 11:52 PM
beeboy's Avatar
beeboy
the Weiand 8010 has it on it too.
Old Feb 14, 2004 | 09:12 PM
ford390gashog's Avatar
ford390gashog
what is the firing order of a 390 is it a clock wise or reverse rotation
Old Feb 14, 2004 | 11:13 PM
LxMan1's Avatar
LxMan1
I believe that it is CCW.
Old Feb 14, 2004 | 11:50 PM
weedscrew's Avatar
weedscrew
Here's a little trick for you: the advance canister always points in the opposite direction of the firing rotation. Visualize your advance canister as an arrow and run your finger in the reverse direction and that should indicate firing rotation direction. This has worked for me with all engines, regardless of make. Good luck!
Old Feb 15, 2004 | 01:17 AM
ford390gashog
thanks
coleaclark
1978 - 1996 Big Bronco
Apr 12, 2008 11:21 AM
1971FordGuy
Feb 9, 2006 03:41 PM
The Diesel Dude
Aug 31, 2002 01:54 PM
lephant
Feb 25, 2002 11:27 PM
NoWake
Nov 12, 2001 03:09 PM
