300 I6 sputter, jerking
Old Feb 9, 2004 | 06:42 PM
galaxie64's Avatar
galaxie64
Unhappy 300 I6 sputter, jerking
CAN ANYONE HELP??? In my 1991 I6 300, F150, it will start and idle beautifully. When I ad power the engine starts to "gargle and " a little, but it's bad enough to cause an uncomfortable jerking. As soon as the rpm get above 2200, (like on the freeway), it runs smooth and powerful. NO "check engine" light or codes. The truck has all new plugs, wires, cap.
Old Feb 10, 2004 | 09:05 PM
downdeephuskyjerk's Avatar
downdeephuskyjerk
try pulling the vac line off of your egr valve once,you will get a check engine light but see if that helps
Old Feb 11, 2004 | 04:09 PM
blueovaldave's Avatar
blueovaldave
I just took off my throttle body to clean it for the same reason and discovered that the gasket was half gone. I went ahead and cleaned the throttle body and installed a new gasket and it runs 100% better.
Old Feb 20, 2004 | 08:33 AM
PKRWUD's Avatar
PKRWUD
Those are two good suggestions. A third would be dirty injectors. I suspect it's your TB gasket, though.
Old Feb 21, 2004 | 06:36 PM
FATMANTPK's Avatar
FATMANTPK
Does this issue only occur when it is extremely hot outside? I had this problem with my 1994 F 150 with the I6, 300 motor. It only happened during the hottest days/months, and only after the engine was very warm.
Old Feb 21, 2004 | 08:36 PM
galaxie64's Avatar
galaxie64
Thank you all for the info. As soon as it gets warmer out, I will check and clean the TB. I will also check the egr valve.
Thank You
Martin.
Old Feb 24, 2004 | 08:59 AM
fordtruckfan90's Avatar
fordtruckfan90
hey guys i kinda have the same problem. I have an egr problem, code 31, EGR control valve sensor. I have a friend that works for ford, he asked mechanics, culd be the valve, the sensor or a buncha things, but i was cleaning out my tb totally, whish was very dirty, and my gasket was bad but put it back on cuz i didnt have a new one, i do have some hesitation at low rpms, hopefully this will solve it!
Old Feb 24, 2004 | 09:01 AM
PKRWUD's Avatar
PKRWUD
Code 31 is either the valve, the sensor, or the wiring harness, and it's pretty easy to diagnose. What have you done so far?
Old Feb 24, 2004 | 11:57 AM
fordtruckfan90
nothing, ran fuel inj cleaner, cleaned out throttle body, I.A.C sensor, checked vac. lines, they r good. I can get the valve and sensor from FORD for $165
Old Feb 24, 2004 | 02:43 PM
PKRWUD's Avatar
PKRWUD
Is your code KOEO, KOER, or Continuous?
Try this; disconnect the harness at the sensor, and stick a jumper in the harness connector between the brown/white wire and the brown/light green wire. Then run the KOEO test again. Look for a code 35 (ignore all other codes, just look for a code 35). If you get a code 35, then the sensor is bad, and needs to be replaced.
Bondsman Chris
Aug 2, 2018 05:32 PM
joshinthe586
2004 - 2008 F150
32
Jul 7, 2018 08:31 PM
Brittany Madl
1997 - 2003 F150
Jan 20, 2017 02:56 PM
Brittany Madl
Jan 14, 2017 11:32 PM
parks911
15
Jun 25, 2004 05:48 PM
