posi rear end
Old Feb 9, 2004 | 06:05 PM
johnyrabbit's Avatar
johnyrabbit
Question posi rear end
I was wondering if I could make my rear end a posi. Someone told me you can weld the spider gears together to make it a posi. Its a 75' ford f100, and I would like to make it posi if that is all it takes.
Old Feb 9, 2004 | 06:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
That is called a Lincoln locker after the welder company. It does not make it a locker. It is similar to putting a spool in. It is dangerous to run a spool on the street.
Old Feb 9, 2004 | 10:16 PM
MustangGT221's Avatar
MustangGT221
posi is the same thing as "limited slip". Posi is a chevy term, limited slip is a ford term. Check out howstuffworks.com and look for the axle stuff, it'll give you a good explanation of how they work.
Old Feb 10, 2004 | 06:48 AM
Boss_358's Avatar
Boss_358
Welding spider gears is not a very safe method no matter how good you can weld. I have heard horror stories of these exploding in mud trucks.
Old Feb 10, 2004 | 04:13 PM
bearfoot_25's Avatar
bearfoot_25
your better off with a spool or mini spool!!!!!
Old Feb 10, 2004 | 06:24 PM
94SSEI's Avatar
94SSEI
how do you know if you have a limited slip diff
Old Feb 10, 2004 | 08:13 PM
grey77's Avatar
grey77
check your trucks printed axle code (driver side door jam). i've been researching the same for my '77 F-100. looks like several mfr's make a manual activated kit. search the net for 'ford manual locker'. also found some at www.truckperformance.com
by the way, there are Code Braker sites on the net also
