Tcase swap
Old Feb 9, 2004 | 05:45 PM
FordPerf300's Avatar
FordPerf300
Tcase swap
Well my 1356 Tcase is on it's way out, with the horrible cost of buying a used one for $550 at a yard and rebuilding it, i have decided to swap in a NP205, costs less and it'll be much stonger. But, I have a driveshaft question, i kno i'll need a longer 2 piece shaft and i would like to know a good place the buy one for at a decent price.
Old Feb 10, 2004 | 12:06 PM
Boss_358's Avatar
Boss_358
I would recommend a local driveline shop if you have one. Truck parts suppliers have a lot of stuff as well. The thing is you may want to have the transfer case in to know how long of a driveshaft you will need. When you determine the length you can either see what the driveline supplier has lying that may fit around or they should be able to make you a new one to the correct specs, including U-joint size.
