Sponsored by: Real Truck
drivetrain questions
Old Mar 30, 2002 | 08:14 AM
Kamikazee's Avatar
Kamikazee
I have a few questions concerning my SD driveline.From what I understand I have a Dana 50 frontend.How durable is that?What are the differences between that and the 2002's Dana 60 front.Does the 50 and 60 share any common parts shuch as u-joints and axles? Now my rearend would be a 10.5 Sterling.Is that a pretty stout setup? Does all the '99 up SD use the same combos; 50 or 60 front with the 10.5 rear? Now one last question,say I would find one of those 6-speed manual tranys, would it be a direct bolt in replacement? could I use a 99-01 trany or would it have to be the 2002 trany? Thanks guys. my truck: 2001 f-250 sc sb 5-speed v10 4.3LS manual hubs & 4x4 engage
Old Mar 30, 2002 | 01:12 PM
Monsta's Avatar
Monsta
Sit. Stay.
>that?
It's my understanding that is not really preferred on a lifted, 4-wheelin' truck. For street use it is fine.
>Dana 60 front.
I know the axle shafts are necked down on the D50. There are more differences than the one that I know off-hand. A real "techie" should be able to give you the full run down.
Compared to what? And for what? Seems stout to me. Although getting better, the available choices in gearing is somewhat slim.
The dually's get the the Dana 80. Pre-'02 Dually's also wore the D60 up front.
>trany?
I have no idea. But where there is a will, there is a way...;-)
Old Mar 30, 2002 | 10:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
>trany?
If you use a 2002 transmission from a V10 it should be a bolt in. Any earlier 6 speed, and the 2002 diesel version, have the wrong bellhousing bolt pattern. It won't bolt to the engine.
Mark
Old Mar 31, 2002 | 06:21 AM
Just4Ford's Avatar
Just4Ford
