Bugflector & Ventvisors
Old Feb 9, 2004 | 12:31 PM
bgriz1027's Avatar
bgriz1027
FTE brothers & sister... You know I come to you guys for everthing before I do it, so her it is. I need to know what is the best brand Bugflector and Ventvisors out. I am haveing a hard time deciding. So I would apprciate you guys opinions and input.
Rod K.
1999 Expediton XLT
Old Feb 9, 2004 | 02:57 PM
Frizzle's Avatar
Frizzle
i have a drawtite in the channel vent visors which is nice because they dont have to go on your paint and a lund stainless steel bug deflector
Old Feb 9, 2004 | 05:16 PM
tsdrallyer's Avatar
tsdrallyer
I use Ventshade side window vents and a Lund clear plastic contoured bug deflrector which you can barely see in my gallery pictures. The ventshades do work well although they do have a tendency every couple of years to work loose from the adhesive used to apply them. The Lund doesn't deflect many bugs from the top of the winshield where I look out, but it has caught and taken the brunt of sever rocks tha would have damaged the leading edge of the hood,, so I now call it a hood protector. If I could find the old cheap, stand up straight and tall deflectors fo the early 90's I'd get one to protect the windshield from bugs and flying debris. They really worked becaue they were tall enough, although not as pretty.
Old Feb 9, 2004 | 06:38 PM
the4by4freek's Avatar
the4by4freek
I got the same set up as TS. The only difference is mine is smoked. Works great at catching rocks! Although I still managed to catch one in the windshield! Now I need a replacement. Oh BTW.... I also have the ventvisor sunroof deflector, Well worth the $45 for it. Sunroof wide open and no noise!
Old Feb 9, 2004 | 06:47 PM
propellerhead's Avatar
propellerhead
Do those bug deflectors really work? It seems like they would only work at certain air speeds.
Old Feb 10, 2004 | 08:26 AM
FarmLaw's Avatar
FarmLaw
They do increase and decrease in effectiveness at certain speeds...but I think the observation that they are best as hood protectors is probably true. I like to have one on my truck simply to protect the leading edge of the hood from getting chipped up from road debris and stones.
Also, at very high speeds, the bug deflector serves as a spoiler and helps with downforce to keep the truck firmly planted on the road. ;-)
Old Feb 10, 2004 | 09:13 AM
KR1's Avatar
KR1
You should be OK ....... the front spoiler will cause more downward force, but tire height should increase due to increased centrifugal force..... : - )
Old Feb 27, 2004 | 06:37 AM
dalfollo's Avatar
dalfollo
You may want to look at the following:
http://www.sportomotoring.com
I just came across the Bugflector II and they have them painted in Ford colors.....I have 2001 wedgewood blue Expy nd I cant decide wether to o painted, clear or smoke....trying to find some pictures to see how it will look...
saw the gallery images of clear...
SuperDoodieDutyDude
6.7L Power Stroke Diesel
Nov 1, 2010 10:56 AM
Bronccat
2009 - 2014 F150
Aug 26, 2009 03:23 PM
4.2Lbeast
Appearance & Dress-Up
Dec 16, 2004 08:54 AM
cingraham
Sep 26, 2003 10:07 AM
