Sponsored by: Auxito
Flasher Replacement
Old Feb 9, 2004 | 10:13 AM
zswalden's Avatar
zswalden
Flasher Replacement
How do I remove the cover off of my rear light assembly to get at the turn signal bulb for replacement?
Old Feb 9, 2004 | 10:18 AM
zswalden's Avatar
zswalden
Oops
Oops. I forgot to mention it's a '99 F-150.
Old Feb 9, 2004 | 01:31 PM
50th ann's Avatar
50th ann
Turn Signal Bulb Change
On my 1998 F 150 you open the tail gate and remove two bolts Aprox 8mm or so and the entire lense will fall out so you can get to the back of it. Twist the bulb socket and it removes from the lense with the bulb in it. pull the bulb out.
Old Feb 9, 2004 | 01:48 PM
zswalden's Avatar
zswalden
I'll try those. Thanks!
