Cold Start Idle Surge
Old Feb 8, 2004 | 11:14 PM
CruisnPhantom's Avatar
CruisnPhantom
Question Cold Start Idle Surge
800 miles thus far on the truck
Cold started it today @ 29 degrees (F) and it started but the idle just started surging up and down for about 10 seconds, and I saw white smoke. It let more white smoke out again when I started it up 20 minutes later. What's the deal?
Old Feb 9, 2004 | 09:35 AM
CruisnPhantom
same thing again this morning, no ideas here? Time to call the dealer?
Old Feb 9, 2004 | 01:08 PM
CruisnPhantom
Nevermind, I discovered I am experiencing Romp/Hunting...thanks
Old Feb 9, 2004 | 01:37 PM
04superduty's Avatar
04superduty
whats romp/ hunting. my truck will sometimes have the idle surge when its very cold out like you described. need to take it in and get it reprogramed again.
Old Feb 9, 2004 | 02:09 PM
TXBDBY's Avatar
TXBDBY
Never heard of Romp hunting, what is that? As for the idle surge, in the cold if the engine does not surge the water does not circulate and heat the inside of your truck! It is nice to get a warm truck when it -20 way up north! Have not had a probelm with the surge. Not sure of white smoke, I know when it is cold that when you are in the throttle that the truck produeces a lot of smoke, but when you let off it is gone.
04, 6.0l, FX4, crew, srw auto and lovin it
Old Feb 9, 2004 | 02:41 PM
Six Liter Fan's Avatar
Six Liter Fan
Hunting is an RPM swing as the engine is trying to maintain speed. Mine does this when it is really cold for the first 30 to 40 seconds until they engine gets a little heat to get proper combustion
Old Feb 9, 2004 | 03:46 PM
Choctaw Bob's Avatar
Choctaw Bob
The variable geometry turbocharger at cold tempratures closes the vanes to increase backpressure so that there will be a quicker warmup. I'm guessing that as pressure builds along with temperature the vanes open then close in response to temperature changes. This would explain the romp. It doesn't seem to be a problem after warmup or on warm days. This engine has some really complicated parts. I don't see how they expect it to last 200K miles.
Old Feb 9, 2004 | 03:55 PM
Six Liter Fan
Bob, "Hunting" happens on all diesels. It is the nature of the ignition event in the diesel. The heat of comression causes ignition and when the cylinders are super cold, combustion is far from perfect. People sometimes use starting fluid to help this. No glow plug engines have even harder times and sometimes refuse to start, but these are typically industrial/ marine engines who use heaters in the water jacket to prevent this.
Hunting also happens on no load conditions if you block off enough of the inlet.
Old Feb 9, 2004 | 06:25 PM
Choctaw Bob
Six Liter Fan - The Romp that is a pain in my D-8 Cat is not acceptable in my $40K 6.0 daily driver especially when my 7.3, the '89 Ford Diesel and even my sorry 83 Caddilic never offered to romp. Ford engineers tried to be cute on this truck. The air management system is nothing like anything ever seen before. Everything depends upon all semsors and valves working perfectly. I have had no trouble with my 6.0 yet but as complicated and fragile as they are, I don't see how they will last the 250,000 miles I have come to expect.
