427 Block
Old Feb 8, 2004 | 10:58 PM
68torino's Avatar
68torino
427 Block
My son is looking to build a 427 which won't be for a while. We have been looking at current mfgs. But have only found Genesis, I had seen Dove from years back but can't find them on the net. Are they still going or are they gone?
Old Feb 8, 2004 | 11:20 PM
Randyb12's Avatar
Randyb12
Caroll Shelby makes all aluminium blocks.
Old Feb 9, 2004 | 08:17 PM
fordeverpower's Avatar
fordeverpower
for the price of a 427 i would build a 390 or 428 instead.
Old Feb 9, 2004 | 08:20 PM
gtex's Avatar
gtex
One of the FTE FE guys, Scouder, is running a Shelby aluminum block. That will cost you in the $5k range, just for the block.
Expect to pay around $2k for a decent rebuildable Ford 427 block.
Check Ebay, they show up frequently, but fetch a good price.
Old Feb 9, 2004 | 08:23 PM
fordeverpower
thats why i will build something other than the 427.
Old Feb 9, 2004 | 08:59 PM
Scouder's Avatar
Scouder
If he wants to build a 427, then he'd better start off my building a 427 instead of a 390 or 428, otherwise it won't be a 427 when he's done. Don't you think? Some people will pay whatever is necessary to have what they want.
68Torino,
There are really only 2 block manufacturers right now. Genesis, who makes iron and aluminum, and Shelby (www.carrollshelbyent.com) who only makes aluminum. Both appear to be excellent pieces. There are starting to be quite a few engines running all of the above with no appreciable problems.
The Shelby block is a little more expensive, but I chose them because of a couple of nice features. First, the custom head studs, which are required, thread into the block farther down along the cylinder bore causing less deck distortion than a standard block that threads right into the deck. Second, the cylinder sleeves come in 2 sizes, standard 4.25", and big bore at 3.75 that can be bored to 4.44. The sleeves are also dry sleeves that can be replaced very easily.
Other than that, the only choice is a used block.
Good luck, and if there is anything I can help you with just let me know.
-Scouder
Old Feb 9, 2004 | 09:43 PM
rusty70f100's Avatar
rusty70f100
I would check DSC motorsports. They have new 427 blocks for $2800, or used ones.
Old Feb 9, 2004 | 09:50 PM
Scouder's Avatar
Scouder
Are those the Genesis iron blocks? If so, that's a pretty good price.
-Scouder
Old Feb 9, 2004 | 11:37 PM
Ratsmoker's Avatar
Ratsmoker
I would imagine but I have never asked him. That is a very good price for an aftermarket iron block though. Out of my budget for sure!
Old Feb 10, 2004 | 11:52 AM
68torino's Avatar
68torino
Thanks for the help guys! I was wondering why I haven't 'found' Dove.
Next, the point for my son wanting to build an all aluminum block 427 is first of course CI. The other major reason is he wants to put it in his '68 Torino formal roof. He dosen't want to have to do a major upgrade in suspension to carry cast iron because at a later date he will want to go back to his factory stock motor which he wants to 'cherry' out and save. He plans on running a C6 with an electronic overdrive he found looking in the catalogs. I haven't checked it out yet. He knows this is going to be along term project with a frame off and the works but he 'lost' a '67 fastback Galaxy and that always bug him so he's stcking with the Torino.
And of course we are hashing out him wanting to run 4.11s with me telling him with 500 to 700 hp in a 427 you can run 2.73s and won't be able to afford rear skins.
Old Feb 10, 2004 | 11:58 AM
Ratsmoker's Avatar
Ratsmoker
I think the shelby blocks are the best aluminum ones out there. They seem to be stronger and have lived at 1500HP already. He's gonna need slicks to take advantage of all the power anyways. You won't be able to gear it to have any traction in first gear on street tires. A 4 link is definitely in order too.
Old Feb 10, 2004 | 12:36 PM
68torino's Avatar
68torino
Thanks Ratsmoker. He won't be using it for the strip(although he will stop there from time to time) he is looking to run it on the street as a daily. No winter. He fiqures the 4.11s with some type of OD will work. I fiqure run a stout C6 with 2.73s or there abouts will do. I also told him 400 to 500 is way plenty for the street but he sees the big numbers and starts drooling.
But we'll see.
He loves his '68 which when we looked at some books found out was called a Formal Roof. These got used for the GTs. To me it's a two door hardtop no posts.
Old Feb 10, 2004 | 12:56 PM
Ratsmoker's Avatar
Ratsmoker
The only thing I don't like about running low gears like 2.73s and 3.00 is that with an engine like that you will obviously need a high stall converter. It creates a lot of heat when you are in the slip range. 4.11 gears will get it out of the slip range with little effort. Also cruising at 2,500 rpm with a 3,500rpm stall creates heat. I myself would feel best cruising down the highway at 3,500rpm with an engine that souped up. With 3.70 gears I turn about 3,000rpm at 70MPH and I have a 3,200 stall. It seems to stay very cool at those speeds. I have a 3,600 stall that I will be installing with my 4.56 gears. The C6 will take all the power you can throw at it if it is built right. They use modified C6 trannies in monster trucks all the time. They are the toughest tranny out there with the exception of the powerglide.
Old Feb 11, 2004 | 12:02 AM
averagef250's Avatar
averagef250
I agree totally with ratsmoker, I ran the stock 3.08 peg leg rear under my old drag truck at first with about 450 horse a 3500 stall, etc. and the tranny temp would heat way up even cruising. with the 4.10's it ran great cruising at around 3500-4000 on the freeway. I never figured gas mileage with the 3.08's, but I got 14 mpg+ with that nasty small block in a 4000 pound truck cruising at 4000 RPM and a 700 double pumper holley w/50cc pump. Not too bad if you ask me.
Old Feb 11, 2004 | 01:26 PM
68torino's Avatar
68torino
I think it comes down to setup. A friend of mine in the Army in the '70s had a Grand Prix Model J with a stroked 400, stock T400 and somewhere around 3.3 rear gears. This thing weighed in over 4000 lbs and would crise at 75 all day long and return 25 miles to the gallon. So if my son runs 400 to 500hp in a 3200 lb car with something in 3.00 to 3.30 I'm betting it will live and work great. Ihave run a Mark IV and a 454 Impala both had gears under 3.50 with the Impala coming in at 2.73 or so and both were very heavy and were great highway cruisers.
muscletruck
55
Jul 2, 2009 04:01 PM
rebelman108
Dec 2, 2008 10:48 PM
tonpartain
19
Feb 25, 2006 07:37 AM
Huntersbo
25
Sep 24, 2005 01:31 PM
Peter Colwill
Sep 7, 1999 06:06 PM
