i have an 89 f150 with a 300ci i6, i live in the booneys and drive 35 miles to work everyday and my heater doesnt work right heres the deal, i can feel it come out at under 40 mph above that i can feel slight air if i put my hand to the vents but its always cold if i drive around town a bit 35mph or lower i get warm half the time but i need hel0p its cold and a half hour drive freezing my *** off isnt fun its usauly 0-10 degrees and i freeze the whole way noit willing to drive 35 mph so can u help me out i just changed my thermostat, o yeah another thing is my temp gauge is always on cold on the dash(never moves if its 0 deggrees or 95 degrees) if thata helps i was thinking cvaccum leak but not sure thanks for ne help later
Sounds like you have two problems, I have some questions;
1. How long ago did you replace your thermostat?
2. Did the temp gauge register normal temp before the thermostat swap?
I do not know your technical abilities, so pardon me if I insult your intelligence. I usually work with the "I know where the gas goes" crowd.
Your second problem can be diagnosed with a simple test.
1. Set your heater to FLOOR and blower to HIGH.
2. With the engine running, step on the gas and take it up to 1500-2000 RPM's. In Park, in the driveway is fine.
3. Check to see if the air flow changes from the floor vents to defrost vents by itself.
If this is the case, check your vaccum check valve or reservoir, if these are OK check the Floor vaccum motor. The airflow problem sounds like a vaccum leak and the heat problem could be an air pocket, water pump, blocked heater core, or a faulty thermostat. Trust me, I have seen new parts fail right out of the box.
