Modular V10 (6.8l)
V10 spark plugs
Old Feb 7, 2004 | 09:14 PM
1bigford's Avatar
1bigford
V10 spark plugs
I've heard they have had problems in the past with spark plugs coming loose or actually coming out. I have a 2003 V10 X is this still a problem
Old Feb 7, 2004 | 10:49 PM
Dwinn's Avatar
Dwinn
Possibly... I have a 2000 V10 and hadn't had any problems. There has been a lot of posts out here on that subject. As I recall, a few people said pat of the problem has to do with having the right plugs, Making sure you use the right thread sealer/compound (or maybe thread lube), and getting them tightened to the right torque. I've only read of a few people out here that have had that problem. Seems that Ford doesn't want to acknowledge the problem.
Old Feb 9, 2004 | 08:04 PM
BigRyanKP's Avatar
BigRyanKP
i think it was only a problem in the 1999 V10 because they have different heads... not positive though...
Old Feb 10, 2004 | 04:10 AM
Brian_Puff's Avatar
Brian_Puff
my 2000 had the shorter threads. the new plugs i installed had more threads on the plugs than the originals.
i wouldnt go worrying too much about blowing a plug out through your hood...
if you are worried about it, just on every other few oil changes just go in and check to see all the plugs are tight. it may seem like alot of work, but it only takes about 45 minutes or so to do them all.
Old Feb 28, 2004 | 01:57 PM
MR_F-350_4X4's Avatar
MR_F-350_4X4
my v10 plug came loose at 87,000 it a was a gradule thing sounded like i had a craked header and it was leaking didnt have the time or money to deal with it at the time so i let it go about 2500 miles later my plug completely ejected and blew hole out of my hood!.... just kidding only broke the coil pack mount(plastic)
unfortunate but repair was not that difficult. timecert.com has a great kit this repair.
