I have replaced several parts and cleared out all the pesky codes except for:
176 : Heated Exhaust Gas Oxygen Sensor - voltage signal indicates lean (Bank 2)
and
177 : Heated Exhaust Gas Oxygen Sensor - voltage signal indicates rich (Bank 2)
Hmmm...same sensor indicating both rich and lean? Sounds like a bad sensor to me.
So here is my silly question: Where do I find the Bank 2 HEGO Sensor?
I have seen several posts on O2 sensor locations that seem to be conflicting (left side, right side, passenger side, driver's side) so please make it simple for me, a product of a rural west Texas education.
are you sure you have a 94 because it did not come with the 4.9l and even if it did it would have awd not 4wd. anyway sounds like you have a vaccum leak or a clogged fuel filter
