i have a 2003 f-250 6.0. mainly at higher speeds ( 65-75) motor bucks and sometimes stalls (not a fun thing). i thought it might be the cam sensor but ford says it shouldnt go bad already.(13,000 mi.) they also said something about fuel leaking into oil. checked level, does seem little high but doesnt seem to smell like fuel. can i test the cps? any thoughts would be great.
p.s. note to ford- 2nd new truck in 3 years with problems. thats strike 2 in my book.
Either that or you have an injector going bad. Take a sample of your oil and send it to Blackstone Labs. Go to their website and they will mail you a sample kit. It is pretty fast. They will send a report by email.
Had the same problem with my 6.0. It's a scary thing when it happens in rush hour traffic. Turned out to be a chaffed wiring harness. Took about 2 hrs in the shop to diagnose and repair.
They knew what it was and couldn't fix it ? Very strange occurence, glad I don't have that dealer....
The fact that the tech made the claim to you -- and this is a very well known problem (fuel injectors) should raise considerable "credibility" issues with that dealership. I wonder if they actually wrote that on the work order copy given back to you after their evaluation. ??
ford drained the oil. pulled out 10 gallons of oil/ fuel mix. they are preasure testing engine to find out where its comming from. let ya know when i know
