Offroad & 4x4
4 Wheeldrive Trans
Old Feb 6, 2004 | 06:19 PM
Magic's Avatar
Magic
4 Wheeldrive Trans
Have a 4 wheel drive truck in my shop,that is lacking a Engine and transmission. What I am in need of is a transmission and transfer case that is made so that the front drive shaft is on the left side of the transmission,facing the front of the truck. NOT on the drivers side. What year did ford build a transmission/and transfer case like this? Most I have seen have the driveshaft under the driver. But I can't use it because my front third member is on the other side not the drivers side. THANKS !!
Old Feb 6, 2004 | 06:23 PM
red_rocket's Avatar
red_rocket
I don't think ford has made a truck like that since the 50's..
Old Feb 6, 2004 | 07:43 PM
rebocardo's Avatar
rebocardo
The Jeeps have their axle pumpkin located on the pass. (right) hand side.
Old Feb 6, 2004 | 07:51 PM
dogman's Avatar
dogman
Magic
what year is your truck???
Old Feb 6, 2004 | 08:48 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Someyone must have swapped in a GM, Jeep, or Dodge.
Old Feb 7, 2004 | 02:41 AM
red_rocket's Avatar
red_rocket
hmm.. most jeeps and dodges I've seen had drivers side drops aswell..
Old Feb 7, 2004 | 06:27 PM
fordmudrunner2020's Avatar
fordmudrunner2020
You might need to get a chevy t-case to bolt behind the tranny. Red Dodges and Jeeps had the diffs on both sides the later ones have it on the driverside and the early ones like the 80's have it on the passenger side.
Old Feb 7, 2004 | 09:37 PM
monsterbaby's Avatar
monsterbaby
Even chebbie has gone to driversides driveshafts but find a transfer case from a dodge or chev from the 70s or 80s, and bolt it to your trans if you are using a manuel, but if auto then might have to redrill align holes in the adapter for the align pins to be right (not sure about the redrill but it might just bolt up)
Old Feb 8, 2004 | 12:23 AM
SoCalDesertRider's Avatar
SoCalDesertRider
Yeah that's wierd, every Ford I've seen has the front shaft on the driver's side. I agree, that must be a front axle from a Chevy.
Old Feb 8, 2004 | 02:08 AM
fishmanndotcom's Avatar
fishmanndotcom
Ford didn't do that from the factory.....someone has been tamperin with your stuff! run the axle codes and see what you get!
-jason-
krock26
Feb 20, 2015 08:12 PM
smashclash
Sep 7, 2010 08:22 AM
seminaryranger
Feb 23, 2010 01:06 AM
BCO2JCO
Jul 22, 2007 10:12 PM
fairlaniac
Nov 22, 2006 07:31 AM
