hard downshift
Old Feb 6, 2004 | 08:23 AM
DHinSC's Avatar
DHinSC
Unhappy hard downshift
My 1996 Explorer has begun to downshift hard into first as I slow to a stop. Two years ago I had the torque converter rebuilt when it went out. Last year I had the transmission rebuilt because it was beginning to slip. Now about a year later, it has begun to shift hard when stopping. I replaced the transmission fluid and filter but that did not help. Any ideas where to go next?
Old Feb 6, 2004 | 04:50 PM
phonebem's Avatar
phonebem
Do you get any other symptoms like the OD off light flashing or any check engine lights? I had a '95 that started doing the same thing and it was caused by a fault in the EGR sensor making the computer go stupid and screwing with the tranny shift points.
Old Feb 7, 2004 | 03:03 PM
DHinSC's Avatar
DHinSC
No other symptoms. The check engine light comes on periodically but doesn't seem to coincide but the hard downshifting is constant. I have suspected the differential pressure sensor for the check engine light. I blew out the hoses and it seemed to help for awhile. Maybe I should replace it and see if the shifting gets better.
Ericinkc
1997 - 2003 F150
May 27, 2016 01:03 AM
BAD RONALD
Crossovers
Feb 20, 2014 02:54 PM
duckhunter88
Jul 28, 2013 12:48 PM
RRousta
Feb 7, 2013 03:07 PM
DHinSC
Jun 10, 2004 05:04 PM
