Sponsored by: Kumho
Front drum to disk conversion?
Old Feb 5, 2004 | 09:48 PM
Hillbillydeluxe's Avatar
Hillbillydeluxe
Question Front drum to disk conversion?
I have searched through this forum and havent found anything and hopefully someone will know. I have a 1975 F-100 with a HP44 and drum brakes in the front. What I need to know is what would it take to convert to disk? The drum brakes really suck! It has power assist but still doesnt stop well. Is it a pretty straight foward conversion or will I need to change abunch of stuff? I know I'll need the rotors, calibers, proportion valve and spindles. What else would I need. Thanks in advance!
Old Feb 6, 2004 | 07:29 AM
72f100's Avatar
72f100
In the long run it will probably be cheaper and easier to buy a whole new front axle. Get one out of an F150 (up to 79) and it should bolt right in, make sure you get the same gear ratio though. I found a 3/4 ton 44 w/ disc brakes and dual piston caliper for less than $200 locally.
Old Feb 6, 2004 | 08:07 PM
Hillbillydeluxe
Thanks, that may be an option. I just dont know how plentyful one with 4:11 will be. I'll look around though. Thanks a bunch!
MUJA1001
35
Dec 12, 2010 08:32 PM
peoria_f100
May 13, 2008 09:20 AM
peanut2001
Dec 30, 2005 08:54 AM
gonefishin
15
Nov 2, 2002 06:11 AM
mikev
Dec 16, 2001 08:37 PM
