Sponsored by: Real Truck
Gauge Lens Replacement
Old Apr 5, 2002 | 08:26 PM
4x4x4x4's Avatar
4x4x4x4
Does anyone know what is involved when replacing the clear gauge lens on a 02 SD?Is the outermost dash panel the only thing that needs to be removed?If so,what holds this in place?
I've got a few scratches on my lens apparently from being mishandled somewhere in the manufacturing process and was wondering what the dealer will have to do in order to replace the clear lens covering the gauges.
Thanks
Old Apr 5, 2002 | 09:24 PM
Yeti's Avatar
Yeti
[updated:LAST EDITED ON 05-Apr-02 AT 10:30 PM (EST)]I'm assuming it's like an 01, so first you pull the headlight switch panel off, pry on bottom of panel with small screw driver and it will pop right out. Then you may or may not have to pull the radio, I didn't. Then pull the main dash off, just pulls off , no screws at all. Just go slow when pulling the dash face apart, dont pull one side to much, kinda work around it.
Once all plugs are dissconnected in back , move shifter (if auto)down and pull the dash out of the way. 4 screws hold the cluster in, remove them, lens will pull apart from gauge face. Thats it took me 10 minutes no hassles,
Old Apr 6, 2002 | 03:14 PM
4x4x4x4's Avatar
4x4x4x4
Thanks for the instructions.
Old Apr 16, 2002 | 09:02 PM
steve nash's Avatar
steve nash
Pull the radio out and the trim panel pops out and you can take the 5.5mm screws out.
Old Apr 16, 2002 | 09:17 PM
Monsta's Avatar
Monsta
Sit. Stay.
You forgot to mention that to remove the radio you need a special tool. It is available at Wal-Mart.
Old Apr 16, 2002 | 09:21 PM
FortyFords's Avatar
FortyFords
Or Auto Zone!!!!!!!!!!
Pepboys
But I don't shop there
They don't have x parts He HE He !!!!!!!!
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old Apr 17, 2002 | 02:11 AM
V10man's Avatar
V10man
On my 99 there are 2 7mm screws in the radio opening that need to come out too before pulling the dash off.
Old Apr 17, 2002 | 05:28 AM
gjvoight's Avatar
gjvoight
