Sponsored by: Real Truck
New Ford Beast.....
Old Feb 5, 2004 | 10:00 PM
DS02F250's Avatar
DS02F250
Also I checked out your ride, pretty sweet!
My humble thanks... which one? The '02 or the '59?
Old Feb 5, 2004 | 10:24 PM
wbarber_07458's Avatar
wbarber_07458
Re: New Ford Beast.....
Originally posted by 1 Black Beast!
Also for anyone with a lift....I'm looking at installing some rubber sheeting in the wheel wells to help keep snow,salt, grime from entering the engine compartment and so forth. Has anyone done this? I'd appreciate ideas. I planned on finding some 1/8" or so thick rubber (sheeting), cutting to mold into place and attaching with fasteners......
I was planning to put the Excursion splash guards on my truck when it shows up (hopefully very soon). I put a thread on the Excursion forum asking for part numbers, but no one knew.
Here is a thread from Diesel Stop that my old man pointed out to me - it has the part numbers. I haven't tried these out yet on the local dealer - if anyone does I would be interested to hear how it goes.
Splash Guard Thread
I think that regardless of whether you lift the truck or not there is a gigantic opening that should be closed off. Why Ford doesn't put these on all trucks is beyond me.
Bill
Old Feb 6, 2004 | 04:29 PM
gw90r8's Avatar
gw90r8
I made a set of these covers from rubber roofing material, I used a 1989 F-350 as a example to follow. The covers I made have been thru 3 winters of plowing are are still just like new. I used a combination of plastic christmas tree fastners and self drilling screws for attachment. The screws were then painted and undercoated. No problems with the so far and they keep all the nasty stuff out of the engine compartment. Sorry I do not have a digi to take pictures with yet.
Old Feb 6, 2004 | 05:10 PM
1 Black Beast!'s Avatar
1 Black Beast!
gw90r8, thanks that sounds like another good idea, AND yours has been tested for three years.
Question though...your not talking about the paper felt that goes under the asphalt shingles....I guess I'm not familiar with rubber roofing material. Thanks for oyu help. Ken
Old Feb 6, 2004 | 06:38 PM
Shadow Hills Super Duty's Avatar
Hey Beast,
Do an internet search for " lift lips ". There are a few companies that already make what I think you are looking for ?
Old Feb 6, 2004 | 07:09 PM
gw90r8's Avatar
gw90r8
The rubber roofing material I am using comes on wide rolls, it is used for large flat roofs, sometimes these roofs are called membrame roofs. The stuff is maybe 1/8 to 3/16 thick and very pliable. Sometimes this rubber is white on one side and black on the other side. It is manufactured to withstand what ever Mother Nature can send its way, middle of the summer 100 degrees plus to middle of the winter and this winter has been 20 to 30 degrees below zero with ice and snow.
By the way my 2001 F-250 just turned 20K miles yesterday while plowing and it is snowing now so another 8 to 10 hours of plowing and maybe sanding once I leave work tonight.
Old Feb 6, 2004 | 09:26 PM
1 Black Beast!
Wow, thank you to everyone! In 24 hours a whole lot of sound ideas, all of which would work.
Shadow Hills, thanks for the tip, I had never heard the term lift lips. I did do a search and I think I'll go with them. $49.00 for the four piece set, custom to each vehicle. The simple way out for sure but for $50 bucks and shipping sounds ideal.
Thanks again...BTW as long as I'm soliciting help and have no shame, can I ask another.....I took my Reece electric brakes controller out of my old vehicle and want to put it in the beast. I can't find where to plug the six point thing in. I see the outlet receptacle sort of under the radio area put it's a long narrow connection for.......????? I don't know what. Is this for the electric brakes and I need change the adaptor? I've searched the owners manual and there is no mention of where electric brakes controller, connects.
Thanks again, and I look forward to helping you all out as well, whenever I can. O.k., here is one repayment of help already....A movie tip. Went and seen Miracle tonight with the family. Great movie, based on true story of our USA Olmpic Team beating the Russians and ultimately winning the gold medal in 1980. Long movie though, like 2 hrs and 15 minutes.
Old Feb 6, 2004 | 11:56 PM
Hope this helps:
Ford vehicles with tow package: A factory tow package plug located under the dash mates to the brake control adapter harness (supplied by Ford or boughtseparately). Plug the adapter into the factory plug. Probe the adapter wires using
a circuit tester to verify the functions (typically on Ford vehicles the green or light red wire is the ÒBattery (+)Ó, White wire is ÒGround (-)Ó, green wire or ight green wire is ÒStoplightÓ, & blue wire is for the ÒTrailer BrakesÓ. After probing, wire the
brake control Power Module to the corresponding wires on the brake adapter and plug the brake control adapter harness into the factory plug.
Oh and by the way I lived in Lake Placid , N.Y when that game was played. Although I'm not a hockey fan I can tell you that the whole area was an exciting place to be at that time.
Old Feb 7, 2004 | 12:29 AM
1 Black Beast!
O.k., thanks Shadow Hills..I'm calling it a night!
I'll resume this mystery tomorrow. None of the wire colors match up with what you are telling me or what I have researched. I'm thinking that since I bought my truck when it was a year old...someone may have changed over the Ford 6 plug adaptor to fit something else into it. I say this because in the area everyone describes as being for the electric brake plug...I find a oblong connection, about 2" wide and 1/3" high, it has I believe 7 small gauge wires going into it and not the blue, red, black, white described for the plug I'm searching for. Most of them are multi colored.
Guess I'll have to stop by the delaership and look at a new one to see what type of connection fitting is supposed to be there. Or, maybe the fitting I'm looking at is for some other device?
Thanks for everyones help.
Old Feb 7, 2004 | 10:42 AM
1 Black Beast!
Geesh! I finally figured it out! Sorry, this is my first Ford, used to have GM discount so always had GM trucks.
The connection I wondered about being the electric brake hookup is the computer diagnostic port! I found the electric brake connector stuffed up inside the dash above this area. Plugged it in, mounted, done in five minutes. Once again, knowledge is everything...or lack of it will cost you three hours!
Thanks everyone!
Old Feb 7, 2004 | 11:35 AM
DeerSniper's Avatar
DeerSniper
What kind of grille is that again? Is it plastic. I want a metal one. The POS factory one has the "chrome" coming off where water runs down it.
Thanks.
Old Feb 7, 2004 | 05:15 PM
LilBlackCoupe's Avatar
LilBlackCoupe
Looks sweet!
Old Feb 7, 2004 | 05:22 PM
  #28
1 Black Beast!
Deersniper...the grill is billet style....they are pretty common in the aftermarket arena. And no it's not plastic....chrome.
Thanks LilBlackCoupe. I used the have 86 T-Bird Turbo Coupe about ten years ago. My wife misses it but we got rid of it one fall because it really couldn't be driven in winter and we didn't have space or funds for keeping it after getting her a front wheel drive vehicle. My wife occassionaly mentions how that was the best car she ever had. It was fun to drive, 5 speed.
Old Feb 8, 2004 | 06:51 AM
  #29
1 Black Beast!
FYI, just wanted to let the people know following this thread....I inadvertantly posted a new thread yesturday when replying, instead of on this thread. You'll see it titled: 1 Black Beast update, I put the pics there. Thanks again!
